주요 콘텐츠로 건너뛰기
How to Repair a Detached Hairbrush Bristle Pad
필요한 것
  1. How to Repair a Detached Hairbrush Bristle Pad, How to Repair a Detached Hairbrush Bristle Pad: 1 단계, 이미지 3개 중 1개 How to Repair a Detached Hairbrush Bristle Pad, How to Repair a Detached Hairbrush Bristle Pad: 1 단계, 이미지 3개 중 2개 How to Repair a Detached Hairbrush Bristle Pad, How to Repair a Detached Hairbrush Bristle Pad: 1 단계, 이미지 3개 중 3개
    • Remove the bristle pad completely from the hairbrush.
  2. How to Repair a Detached Hairbrush Bristle Pad: 2 단계, 이미지 2개 중 1개 How to Repair a Detached Hairbrush Bristle Pad: 2 단계, 이미지 2개 중 2개
    • Thoroughly clean the brush base and bristle pad by rinsing them under hot water and using a brush.
    • Ensure that the area where the glue is to be applied is free of any debris or old adhesive. A vacuum or compressed air can be used to remove debris if necessary.
  3. How to Repair a Detached Hairbrush Bristle Pad: 3 단계, 이미지 2개 중 1개 How to Repair a Detached Hairbrush Bristle Pad: 3 단계, 이미지 2개 중 2개
    • Pat the brush dry using a cloth or a paper towel.
    • Wait until the bristle pad and brush are completely dry before moving on.
  4. How to Repair a Detached Hairbrush Bristle Pad: 4 단계, 이미지 3개 중 1개 How to Repair a Detached Hairbrush Bristle Pad: 4 단계, 이미지 3개 중 2개 How to Repair a Detached Hairbrush Bristle Pad: 4 단계, 이미지 3개 중 3개
    • Use a hot glue gun or superglue to apply a thin, even layer around the edges of the brush base where the pad originally sat.
  5. How to Repair a Detached Hairbrush Bristle Pad: 5 단계, 이미지 2개 중 1개 How to Repair a Detached Hairbrush Bristle Pad: 5 단계, 이미지 2개 중 2개
    • Carefully align the bristle pad with the brush base, and firmly press it down, ensuring the glue spreads evenly and bonds the pad to the base.
  6. How to Repair a Detached Hairbrush Bristle Pad: 6 단계, 이미지 1개 중 1개
    • Wipe away any excess glue.
  7. How to Repair a Detached Hairbrush Bristle Pad: 7 단계, 이미지 2개 중 1개 How to Repair a Detached Hairbrush Bristle Pad: 7 단계, 이미지 2개 중 2개
    • Leave a weight on top of the bristle side of the hairbrush to allow a good seal while the glue dries. Ensure the weight is light enough that it does not bend the bristles out of shape.
    • Leave the weight on as long as it takes for the glue to dry.
    • Allow the glue to dry completely before using your brush again. Drying times can vary between glue products. While hot glue dries relatively quickly, it can still take 24-48 hours to fully cure.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Akshay
회원 가입일: 01/30/25
175 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 23
전체 시간: 179
