소개
Over time, the wire coating of an Apple MagSafe Power Adaptor may deteriorate leaving the wires exposed and possibly subject to electrical shorts. By covering the exposed wires with heat shrink you can protect the power adapter and yourself while continuing to charge your computer.
Locate the damaged or exposed area on the adaptor wire.
Move the wire connector away from the damaged or exposed area.
The 3/8" in Heat Shrink Tube has a maximum shrinking capacity that is larger than the Mac Charger Wire's Diameter. So to create a proper hold, we need to increase it's diameter in some way. Wrap around it with an electric tape or this sample red wire covering in the picture, to increase it's diameter before shrinking it all the way into place.
Since the end of the charger has a bigger diameter than the wire, it seems to have a nice snug fit. If you feel it is necessary to add more body in the diameter of that part then just cover it with electric tape, etc, before shrinking the heat shrink tube in that area.
Apple MagSafe Power Adapters typically range from $70-$80. By following this simple repair you can save money and continue using your power adaptor. People with similar wire coating issues and different power adaptors can hopefully find this repair guide helpful since the repair process is nearly identical.
다른 31명이 해당 안내서를 완성하였습니다.
댓글 9개
Thanks! Wish I had seen this repair technique a long time ago... would have saved a lot of money on buying new power supplies and an expensive laptop repair when a cracked cable shorted out. Much appreciated!
This method fried my cable and it stopped working… Do not recommend anyone to try it. Now I have to buy a new one…
Minimum sensitivity required. I think you missed the part where it reads…
“When heating, always keep the heat gun moving around the heat shrink. Do not apply heat to one location for too long. Overheating the heat shrink may cause further damage to the wire or wire coating underneath, and may melt the heat shrink itself.”
I know this is from 2017, but I had a big laugh when I read John Myr’s post. Who in their right mind would even attempt to make a repair if you don’t know how to use a heat gun or even a cig lighter? Further don’t try a repair if you don’t understand how to shrink shrink tube! LOL LOL I would have paid money to see this guy burn through his cord! OMG, thanks for the big laugh!
where do i get the red stuff??
