주요 콘텐츠로 건너뛰기
How to Repair a Frayed Dell AC Adapter Cable
필요한 것
  1. How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 1 단계, 이미지 3개 중 1개 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 1 단계, 이미지 3개 중 2개 How to Repair a Frayed Dell AC Adapter Cable, How to Repair a Frayed Dell AC Adapter Cable: 1 단계, 이미지 3개 중 3개
    • Be sure to unplug the power supply from the wall before doing any work to prevent electric shock.
    • Inspect the frayed power supply end for spots that you can cut off the connector insulation without damaging the wires.
    • Cut the insulation off the connector using wire cutters, scissors, or a sharp knife.
  2. How to Repair a Frayed Dell AC Adapter Cable: 2 단계, 이미지 3개 중 1개 How to Repair a Frayed Dell AC Adapter Cable: 2 단계, 이미지 3개 중 2개 How to Repair a Frayed Dell AC Adapter Cable: 2 단계, 이미지 3개 중 3개
    • There will be two wires in the connector. One wire comes from the inner cable and the other comes from the frayed outer cable. Find the wire associated with the frayed outer cable.
    • Use a small sharp knife, such as hobby knife, to cut the wire free of the plastic casing.
    • Be sure not to cut or damage the wire.
  3. How to Repair a Frayed Dell AC Adapter Cable: 3 단계, 이미지 3개 중 1개 How to Repair a Frayed Dell AC Adapter Cable: 3 단계, 이미지 3개 중 2개 How to Repair a Frayed Dell AC Adapter Cable: 3 단계, 이미지 3개 중 3개
    • Inspect the wires and determine if there are enough strands that can be soldered together to make a safe, reliable connection.
    • If you can make a good connection with the old wires, press them together so there are no strands fraying outward.
    • If there are only a couple wires still connected and the severed ends can not reach each other, or the wire is completely severed, you will need to splice in some new wire.
  4. How to Repair a Frayed Dell AC Adapter Cable: 4 단계, 이미지 2개 중 1개 How to Repair a Frayed Dell AC Adapter Cable: 4 단계, 이미지 2개 중 2개
    • Solder the old, or new, wires together, making sure that the solder flows a little past the damaged area.
    • Re-settle the wire back into the white casing as best as possible.
  5. How to Repair a Frayed Dell AC Adapter Cable: 5 단계, 이미지 3개 중 1개 How to Repair a Frayed Dell AC Adapter Cable: 5 단계, 이미지 3개 중 2개 How to Repair a Frayed Dell AC Adapter Cable: 5 단계, 이미지 3개 중 3개
    • Open the Sugru pack, remove the material, and press it around the connector to make a new connector insulator. It is recommended that your new sheath extends at least .5" past the damaged area.
    • You have approximately 30 minutes to work the Sugru. Then allow about 24 hours for it to fully cure.
결승점
다른 29명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Phillip Takahashi
회원 가입일: 08/22/11
87,618 평판
안내서 87개를 작성함
1가이드 댓글
What do you mean by splicing new wire when completely severed?
K Caye - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 36
지난 30일: 116
전체 시간: 76,555
