주요 콘텐츠로 건너뛰기
How to Repair a Frayed Headphone Cable
필요한 것
  1. How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: 1 단계, 이미지 1/2 How to Repair a Frayed Headphone Cable, How to Repair a Frayed Headphone Cable: 1 단계, 이미지 2/2
    • Cut above the frayed portion of the cable using wire cutters.
    • Using the wire cutters, strip away approximately one inch of wire coating.
    • Use caution to avoid cutting too far into the wire.
  2. How to Repair a Frayed Headphone Cable: 2 단계, 이미지 1/2 How to Repair a Frayed Headphone Cable: 2 단계, 이미지 2/2
    • After stripping the wire, four wires should be exposed. The wires should be three different colors.
    • Red: Right channel
    • Gold/copper: Ground
    • Blue/green: Left channel
    • Twist the two ground wires together.
  3. How to Repair a Frayed Headphone Cable: 3 단계, 이미지 1/2 How to Repair a Frayed Headphone Cable: 3 단계, 이미지 2/2
    • Unscrew the plug housing.
    • Thread the wire through the plug housing.
  4. How to Repair a Frayed Headphone Cable: 4 단계, 이미지 1/1
    • Remove the enamel from the red and blue wires with a wire stripper.
  5. How to Repair a Frayed Headphone Cable: 5 단계, 이미지 1/1
    • With a soldering iron, apply a small amount of solder to the end of each wire.
    • This is especially important for the twisted ground wires; the solder should hold them together.
  6. How to Repair a Frayed Headphone Cable: 6 단계, 이미지 1/3 How to Repair a Frayed Headphone Cable: 6 단계, 이미지 2/3 How to Repair a Frayed Headphone Cable: 6 단계, 이미지 3/3
    • Thread the wires through each hole and wrap them back over.
    • See the third picture for a diagram of where each wire goes.
    • Next, twist each wire with itself to secure it to the lead. This can be seen in the second picture.
  7. How to Repair a Frayed Headphone Cable: 7 단계, 이미지 1/2 How to Repair a Frayed Headphone Cable: 7 단계, 이미지 2/2
    • Solder over each lead's hole, connecting the wire to the lead.
    • Your solder joints should completely cover the hole and surround the wire.
    • After each wire is connected, use a drop of hot glue to secure the wires and prevent them from touching each other.
  8. How to Repair a Frayed Headphone Cable: 8 단계, 이미지 1/1
    • Screw the housing back onto the jack and test your work.
    • If the sound turns on and off this is a connection error. To fix it, look at your solder joints and make sure the wires are fully connected to the leads. If not, apply more solder to the joints, covering the wire.
결승점
다른 28명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 02/24/15
716 평판
안내서 1개 작성함
Cal Poly, Team 23-2, Green Winter 2015 Cal Poly, Team 23-2, Green Winter 2015 회원
CPSU-GREEN-W15S23G2
4 회원들
안내서 15개 작성하였습니다
2 Comments
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
Anderson Barreto - 답글
great instruction - any for repair of cable with microphone ? and even a flat cable ?
LiveVest - 답글
댓글 쓰기
조회 통계:
24 시간 전: 41
7일 전: 258
30일 전: 1,030
전체 시간: 101,388
