소개
Tired of replacing old headphone sets? Here’s a step-by-step guide on repairing frayed headphone cables in an environmentally efficient and affordable way. This guide will require soldering skills.
필요한 것
Cut above the frayed portion of the cable using wire cutters.
Using the wire cutters, strip away approximately one inch of wire coating.
After stripping the wire, four wires should be exposed. The wires should be three different colors.
Red: Right channel
Gold/copper: Ground
Blue/green: Left channel
Twist the two ground wires together.
다른 36명이 해당 안내서를 완성하였습니다.
2 Guide Comments
To me, the more difficult part in this job, is solder.... Now, If you are not sure, with where solder each wire, try with a tester in the continuity mode, and test between the each part of the tip and the three holes. Greetings!
