주요 콘텐츠로 건너뛰기
How to Repair a Guitar Wall Mount
필요한 것
  1. How to Repair a Guitar Wall Mount, How to Repair a Guitar Wall Mount: 1 단계, 이미지 1/2 How to Repair a Guitar Wall Mount, How to Repair a Guitar Wall Mount: 1 단계, 이미지 2/2
    • If the swivel mechanism on the arm of your guitar wall mount is hanging down and isn't responding to pressure, odds are the arm has become disengaged from the gears.
  2. How to Repair a Guitar Wall Mount: 2 단계, 이미지 1/3 How to Repair a Guitar Wall Mount: 2 단계, 이미지 2/3 How to Repair a Guitar Wall Mount: 2 단계, 이미지 3/3
    • Remove the loose arm.
  3. How to Repair a Guitar Wall Mount: 3 단계, 이미지 1/2 How to Repair a Guitar Wall Mount: 3 단계, 이미지 2/2
    • Remove the two 6.5 mm screws from the mount with a Phillips #2 screwdriver.
    • Remove the whole mount from the wall.
  4. How to Repair a Guitar Wall Mount: 4 단계, 이미지 1/2 How to Repair a Guitar Wall Mount: 4 단계, 이미지 2/2
    • Insert the arm's shaft inside the marked circle.
    • Make sure that the gears in the bracket are aligned.
  5. How to Repair a Guitar Wall Mount: 5 단계, 이미지 1/2 How to Repair a Guitar Wall Mount: 5 단계, 이미지 2/2
    • The mount should look like this after correctly inserting the loose arm piece.
  6. How to Repair a Guitar Wall Mount: 6 단계, 이미지 1/3 How to Repair a Guitar Wall Mount: 6 단계, 이미지 2/3 How to Repair a Guitar Wall Mount: 6 단계, 이미지 3/3
    • Make sure the arms swivel appropriately with pressure and without pressure.
결론
Screw your mount back onto the wall, and you're good-to-go!
다른 한 분이 해당 안내서를 완성하였습니다.
Yadiel H Román Matías
회원 가입일: 03/18/22
154 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 209
