주요 콘텐츠로 건너뛰기
How to Repair a Hair Clip with a Detached Spring
필요한 것
  1. How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: 1 단계, 이미지 2개 중 1개 How to Repair a Hair Clip with a Detached Spring, How to Repair a Hair Clip with a Detached Spring: 1 단계, 이미지 2개 중 2개
    • Place the two pieces of the hair clip together.
    • The circles on the top of the clip should align.
  2. How to Repair a Hair Clip with a Detached Spring: 2 단계, 이미지 2개 중 1개 How to Repair a Hair Clip with a Detached Spring: 2 단계, 이미지 2개 중 2개
    • Tie the rubber band around the hair clip to secure the pieces in place.
  3. How to Repair a Hair Clip with a Detached Spring: 3 단계, 이미지 1개 중 1개
    • Insert the pin halfway into the circles on the top of the clip.
  4. How to Repair a Hair Clip with a Detached Spring: 4 단계, 이미지 1개 중 1개
    • Place the spring next to the inserted pin with the two edges facing upwards.
  5. How to Repair a Hair Clip with a Detached Spring: 5 단계, 이미지 1개 중 1개
    • Use the pliers to push the pin through the spring and remaining holes.
  6. How to Repair a Hair Clip with a Detached Spring: 6 단계, 이미지 3개 중 1개 How to Repair a Hair Clip with a Detached Spring: 6 단계, 이미지 3개 중 2개 How to Repair a Hair Clip with a Detached Spring: 6 단계, 이미지 3개 중 3개
    • Take the rubber band off and test the repair.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Evelyn Saravia
회원 가입일: 10/10/21
358 평판
안내서 1개를 작성함
6가이드 댓글
Where do I get the springs from?
Jessica stone - 답글
Where can I get new pins?
Nancy P. - 답글
Did anyone get answers for the springs and pin questions? Where do we get those?
Julianna Di Miceli - 답글
From Hungary and I found springs for sale in a designated shop online, but they're insanely overpriced. One spring goes for 1.49 in USD for which I can buy a brand new hair clip for... Wild how much they charge for a tiny piece of bent wire!
Georgina - 답글
Me encantooo!!! Si no que no le puse la coleta eso por que mi traba era una flor y me molestabaa!! Gracias por el tutorial, me sirvió mucho...
lucía - 답글
댓글 쓰기
조회 통계:
지난 24시간: 54
지난 7일: 448
지난 30일: 2,042
전체 시간: 96,926
