주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Hole in the Wall Using Spackle
필요한 것
  1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 1 단계, 이미지 3개 중 1개 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 1 단계, 이미지 3개 중 2개 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: 1 단계, 이미지 3개 중 3개
    • Prepare the damaged surface by cleaning and removing all dust and debris.
    • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
    댓글 쓰기
  2. How to Repair a Hole in  the Wall Using Spackle: 2 단계, 이미지 3개 중 1개 How to Repair a Hole in  the Wall Using Spackle: 2 단계, 이미지 3개 중 2개 How to Repair a Hole in  the Wall Using Spackle: 2 단계, 이미지 3개 중 3개
    • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
    • Press patch firmly to ensure a strong bond to the wall.
    댓글 쓰기
  3. How to Repair a Hole in  the Wall Using Spackle: 3 단계, 이미지 3개 중 1개 How to Repair a Hole in  the Wall Using Spackle: 3 단계, 이미지 3개 중 2개 How to Repair a Hole in  the Wall Using Spackle: 3 단계, 이미지 3개 중 3개
    • Open container and mix spackling compound before applying.
    • Mix thoroughly to have a smooth application.
    댓글 쓰기
  4. How to Repair a Hole in  the Wall Using Spackle: 4 단계, 이미지 3개 중 1개 How to Repair a Hole in  the Wall Using Spackle: 4 단계, 이미지 3개 중 2개 How to Repair a Hole in  the Wall Using Spackle: 4 단계, 이미지 3개 중 3개
    • Use the putty knife to spread spackling compound evenly over the adhesive patch.
    • Spread the spackling mixture beyond the area intended to cover.
    • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
    댓글 쓰기
  5. How to Repair a Hole in  the Wall Using Spackle: 5 단계, 이미지 2개 중 1개 How to Repair a Hole in  the Wall Using Spackle: 5 단계, 이미지 2개 중 2개
    • Allow the compound to dry completely before moving to the last step.
    • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
    댓글 쓰기
  6. How to Repair a Hole in  the Wall Using Spackle: 6 단계, 이미지 3개 중 1개 How to Repair a Hole in  the Wall Using Spackle: 6 단계, 이미지 3개 중 2개 How to Repair a Hole in  the Wall Using Spackle: 6 단계, 이미지 3개 중 3개
    • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
    • Smooth out any bumps on the surface.
    • Do not sand down to mesh patch.
    • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kerticia Miller
회원 가입일: 01/17/21
205 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 28
지난 30일: 262
전체 시간: 8,074
