주요 콘텐츠로 건너뛰기
How to Repair a Hole in Workout/Yoga Around the Groin
필요한 것
  1. How to Repair a Hole in Workout/Yoga Around the Groin, How to Repair a Hole in Workout/Yoga Around the Groin: 1 단계, 이미지 1/1
    • Take the pants and put them inside out.
    • You want the seams to be showing.
  2. How to Repair a Hole in Workout/Yoga Around the Groin: 2 단계, 이미지 1/1
    • Take the sewing pins (if the hole is big) and pin closed along the seam.
    • This should take no more than 5 pins to do.
  3. How to Repair a Hole in Workout/Yoga Around the Groin: 3 단계, 이미지 1/3 How to Repair a Hole in Workout/Yoga Around the Groin: 3 단계, 이미지 2/3 How to Repair a Hole in Workout/Yoga Around the Groin: 3 단계, 이미지 3/3
    • Take the thread (make sure it is the preferred color that matches the pants) and thread it through the needle.
    • Make sure to leave a large tail at least 20 inches.
    • Tie the two ends together into a small knot.
  4. How to Repair a Hole in Workout/Yoga Around the Groin: 4 단계, 이미지 1/1
    • Insert the needle into the fabric from one side until you can see the needle on the other side.
    • Pull all the way through.
  5. How to Repair a Hole in Workout/Yoga Around the Groin: 5 단계, 이미지 1/1
    • Take the needle and put it back through the fabric a short distance from where it came out originally.
  6. How to Repair a Hole in Workout/Yoga Around the Groin: 6 단계, 이미지 1/1
    • Continue steps 7 and 8 until you have reached the other end of the hole.
  7. How to Repair a Hole in Workout/Yoga Around the Groin: 7 단계, 이미지 1/2 How to Repair a Hole in Workout/Yoga Around the Groin: 7 단계, 이미지 2/2
    • Once you have finished sewing the hole, take the thread and tie a small knot at the base of the thread.
    • Cut thread and reverse the pants to check the seam.
  8. How to Repair a Hole in Workout/Yoga Around the Groin: 8 단계, 이미지 1/1
    • If seam is completely closed, then you have done it!
    • If not, then repeat steps 7-11 until hole is completely closed.
결론
If seam is completely closed, then you have done it! If not, then repeat steps 7-11 until hole is completely closed.
Jessy Sternblitz
회원 가입일: 09/20/23
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 125
