주요 콘텐츠로 건너뛰기
How to Repair a Hole in a Shirt
필요한 것
  1. How to Repair a Hole in a Shirt, How to Repair a Hole in a Shirt: 1 단계, 이미지 1/1
    • Find the hole in the shirt. Spread out the shirt where hole is but don't spread the hole.
  2. How to Repair a Hole in a Shirt: 2 단계, 이미지 1/1
    • After you have found the hole put your hand underneath. Get the needle and thread and from underneath the shirt, start putting the needle through the shirt.
  3. How to Repair a Hole in a Shirt: 3 단계, 이미지 1/1
    • When you have the needle through you will need to stitch the hole close from the inside by going in out of the fabric.
  4. How to Repair a Hole in a Shirt: 4 단계, 이미지 1/1
    • After the hole is closed by stitching it. You will need to go back over the top of the hole called the seem and sew that down flat.
  5. How to Repair a Hole in a Shirt: 5 단계, 이미지 1/2 How to Repair a Hole in a Shirt: 5 단계, 이미지 2/2
    • After the seem is sewn down you do a topstitch which is just a tighter neater regular stitch. After you get the end you will need to to tie a knot and cut the thread.
  6. How to Repair a Hole in a Shirt: 6 단계, 이미지 1/1
    • Here what it is supposed to look like and it is best if you wash the shirt but it doesn't not hurt if you don't.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alexander Gerkensmeyer
회원 가입일: 10/08/19
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 64
전체 시간: 908
