이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Do you have a hole in your Therm-a-Rest backpacking sleeping pad? Follow this guide to locate and patch the hole in your pad using a Therm-a-Rest repair kit, and get back to camping in comfort.
필요한 것
Blow up the sleeping pad full of air using the intake valve in the top left corner.
Open the valve by turning it counter-clock-wise.
Place your mouth over the valve, and blow air into the pad until is is inflated.
With your mouth over the valve, turn the valve clockwise to close it.
This guide can be used to fix similar types of sleeping pads. This patch will help you prolong the life of your camping gear!
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Do I need to deflate the mat before applying the glue?
You could try submerging the inflated sleeping pad in a bathtub. Keep an eye out for small bubbles and you should find your leak.
