주요 콘텐츠로 건너뛰기
How to Repair a Hole in an Air Mattress
필요한 것
  1. How to Repair a Hole in an Air Mattress, How to Repair a Hole in an Air Mattress: 1 단계, 이미지 1개 중 1개
    • Inflate the air mattress fully using either a manual pump (pictured) or an electric pump.
    • An electric pump will save you time and energy so if you have that option definitely choose the electric pump, but know that means you need access to a plug.
  2. How to Repair a Hole in an Air Mattress: 2 단계, 이미지 1개 중 1개
    • Identify the location of the hole.
    • Some techniques to locate holes are listening for air escaping or using soapy water.
  3. How to Repair a Hole in an Air Mattress: 3 단계, 이미지 1개 중 1개
    • Clean around the hole where you plan to put the patch.
    • Use water and allow to air dry.
    • This will ensure a clean surface to attach the adhesive.
  4. How to Repair a Hole in an Air Mattress: 4 단계, 이미지 2개 중 1개 How to Repair a Hole in an Air Mattress: 4 단계, 이미지 2개 중 2개
    • Apply flexible adhesive made for vinyl where the patch is intended.
    • Use a brush or towel to spread adhesive to form an even layer.
  5. How to Repair a Hole in an Air Mattress: 5 단계, 이미지 2개 중 1개 How to Repair a Hole in an Air Mattress: 5 단계, 이미지 2개 중 2개
    • Apply a piece of vinyl patch on top of the adhesive to cover the hole.
    • Smooth out patches to ensure there are no bumps or bubbles.
    • You can smooth out bubbles with your fingers or use a plastic card.
  6. How to Repair a Hole in an Air Mattress: 6 단계, 이미지 1개 중 1개
    • Allow the adhesive to fully dry per adhesive instructions before using the air mattress.
    • Enjoy your fixed air mattress!
결론
To fill any other holes, repeat the same steps as many times as necessary.
작성자
2다른 기여자 명과 함께
Senia
회원 가입일: 02/20/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 19
전체 시간: 419
