주요 콘텐츠로 건너뛰기
How to Repair a Hole in an Inflatable Floatie
필요한 것
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 1/3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 2/3 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 3/3
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: 2 단계, 이미지 1/2 How to Repair a Hole in an Inflatable Floatie: 2 단계, 이미지 2/2
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 1/3 How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 2/3 How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 3/3
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 1/3 How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 2/3 How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 3/3
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 1/3 How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 2/3 How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 3/3
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: 6 단계, 이미지 1/2 How to Repair a Hole in an Inflatable Floatie: 6 단계, 이미지 2/2
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
결론
Enjoy your renewed floatie!
다른 한 분이 해당 안내서를 완성하였습니다.
Selena Barnhart
회원 가입일: 03/01/23
166 평판
안내서 1개 작성함
Austin Community College, Team 60-2, Watkins Spring 2023 Austin Community College, Team 60-2, Watkins Spring 2023 회원
AUSTINCC-WATKINS-S23S60G2
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 168
