주요 콘텐츠로 건너뛰기
How to Repair a Hole in an Inflatable Floatie
필요한 것
  1. How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 3개 중 1개 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 3개 중 2개 How to Repair a Hole in an Inflatable Floatie, How to Repair a Hole in an Inflatable Floatie: 1 단계, 이미지 3개 중 3개
    • If the punctured area is not obvious:
    • Spritz soapy water over different areas of the inflated floatie and press down on the floatie until you see air bubbles.
  2. How to Repair a Hole in an Inflatable Floatie: 2 단계, 이미지 2개 중 1개 How to Repair a Hole in an Inflatable Floatie: 2 단계, 이미지 2개 중 2개
    • Deflate the floatie by pinching the base of the valve stem and pressing down on the floatie to let the air out.
  3. How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 3개 중 1개 How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 3개 중 2개 How to Repair a Hole in an Inflatable Floatie: 3 단계, 이미지 3개 중 3개
    • Clean the punctured area with alcohol wipes in order to help the waterproof tape adhere better.
    • Wait for the alcohol to completely dry.
    • If you do not have alcohol wipes available feel free to use soap, water and a towel. Then let the area dry completely.
  4. How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 3개 중 1개 How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 3개 중 2개 How to Repair a Hole in an Inflatable Floatie: 4 단계, 이미지 3개 중 3개
    • Cut the waterproof tape two centimeters wider than the punctured area.
    • You can cut the waterproof tape in a circle or square; whichever you prefer.
  5. How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 3개 중 1개 How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 3개 중 2개 How to Repair a Hole in an Inflatable Floatie: 5 단계, 이미지 3개 중 3개
    • Peel off the backing of the waterproof tape and center it over the punctured area.
    • Make sure the area is flat that way the waterproof tape will have less air bubbles when applied.
  6. How to Repair a Hole in an Inflatable Floatie: 6 단계, 이미지 2개 중 1개 How to Repair a Hole in an Inflatable Floatie: 6 단계, 이미지 2개 중 2개
    • Press down firmly on the patch making sure no air bubbles are visible.
    • Leave it for about 30 minutes.
    • Inflate your floatie and enjoy the water!
결론
Enjoy your renewed floatie!
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Selena Barnhart
회원 가입일: 03/01/23
214 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 27
지난 30일: 89
전체 시간: 2,379
