주요 콘텐츠로 건너뛰기
How to Repair a Hole on the Shoe Sole
필요한 것
  1. How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 1 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 1 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole, How to Repair a Hole on the Shoe Sole: 1 단계, 이미지 3/3
    • Scrape off any extra material near the area of the hole that is not part of the outsole of the shoe.
    • Clean the outsole with a wet paper towel.
    • Clean and dry the outsole with a paper towel before starting.
  2. How to Repair a Hole on the Shoe Sole: 2 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole: 2 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole: 2 단계, 이미지 3/3
    • Use the 120 grit sandpaper to roughen the edges of the hole on the outsole.
    • This helps the shoe goo adhere more readily to the outsole.
  3. How to Repair a Hole on the Shoe Sole: 3 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole: 3 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole: 3 단계, 이미지 3/3
    • Pull the insole out of the shoe.
    • Apply duct tape inside the shoe (on the other side of the hole).
    • Make sure the duct tape covers up the entire hole, so there will be no shoe goo going through the sole into the shoe.
    • For holes that ripped through the shoe sole and to the inside of the shoe, this step is very important.
  4. How to Repair a Hole on the Shoe Sole: 4 단계, 이미지 1/2 How to Repair a Hole on the Shoe Sole: 4 단계, 이미지 2/2
    • Apply the shoe goo to fill up the hole on the outsole.
    • Apply enough shoe goo to cover up all of the areas of the hole.
  5. How to Repair a Hole on the Shoe Sole: 5 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole: 5 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole: 5 단계, 이미지 3/3
    • Spread the shoe goo evenly with an ice cube to cover up any uncovered area.
    • The shoe goo will not stick to the ice cube, and you will be able to easily spread the shoe goo. The coldness of the ice also helps the shoe goo set in place.
  6. How to Repair a Hole on the Shoe Sole: 6 단계, 이미지 1/1
    • Let the shoe sit for 24 hours for the shoe goo to dry.
    • In this period, do not let any objects come into contact with the glue.
  7. How to Repair a Hole on the Shoe Sole: 7 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole: 7 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole: 7 단계, 이미지 3/3
    • After 24 hours, remove the duct tape from the shoe.
    • Place the insole back into the shoe.
    why would you remove the duct tape if your putting the insole back in?
    gary b - 답글
  8. How to Repair a Hole on the Shoe Sole: 8 단계, 이미지 1/3 How to Repair a Hole on the Shoe Sole: 8 단계, 이미지 2/3 How to Repair a Hole on the Shoe Sole: 8 단계, 이미지 3/3
    • Use the 120 grit sand paper to rub the surface of the outsole until the shoe goo portion is smooth.
    Quella del ghiaccio per spargere la colla e un idea superlativa
    giorgio.dulizia - 답글
    Spargere la colla per scarpe con un cubetto di ghiaccio mi sembra un'idea fuori dall'ordinario
    You can use some other kind of sole glue too to fix holes or even reconstruct parts of a sole.
    They are available in different, common sole colors. With a little experience and patience, the sole can look like new again.
    The advice with the tape protection from the inside and the ice cube are very useful!
    Calix - 답글
결론
Now you can walk again!
다른 30명이 해당 안내서를 완성하였습니다.
Wei Zeng
회원 가입일: 09/29/15
1,028 평판
안내서 1개 작성함
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 회원
CPSU-GREEN-F15S14G4
5 회원들
안내서 16개 작성하였습니다
댓글 10개
Excellent - thank you
Amanda Bowdler - 답글
I used shoe goo on part of the sole that touch the concrete and over about a weeks time it eventually just fell out.
kimdelee - 답글
I wonder if there is any tip for a sole that has a hole all the way through. I tried something similar like this guid but it was quickly worn out. Maybe if I reinforce with duct tape and build the hole up from inside out, then make it a 2 step progress and do the outside first. Let dry for 2 days and then approach the same from the inside. Hmm such a shame certain brands have weak soles
blackwidow - 답글
Buen dia voy a seguir su recomendacion para reparar mis deportivo GRACIAS
Olga rodriguez - 답글
heel patch has to extend a considerable length past the actual part to repair (preferably into any grooves) to reduce edges of the patch from peeling and falling off.
Doug - 답글
Why dont you just buy Shoe sole replacement on amazon or walmart and use the shoe goo the way it was meant and glue the New sole (or just a piece or part, they do sell half sole replacements as well all in various thickness, size, and style) to the shoe over the damage? Shoe goo is meant to bond 2 things together not fill holes..
Kristina M - 답글
I didnt quite get to doug before I made a whole account to rant a bit in a comment.
Smart
Kristina M - 답글
Clean the hole with paper towel sb clean the hole with chemical cleaner and rag. The material must be prep for the shoe goo to stay and not peel off after a few uses. Sanding will help too as will applying glue past the hole onto a crease or tread pattern as Doug mentioned. Some goo inside the hole is OK as it helps hold in the patch just flatten it so there is no lump inside
om1gc - 답글
How prone to wear is the glue alone if compared to the rubber it supputo fill?
Thanks in advance 😃
Bonus tip:
If you have a cracked sole; a hybrid 'caulcing' glue (the one from a caulking gun) did the trick for me; but I assume it will wear quite fast as a sole.
NederLof - 답글
댓글 쓰기
조회 통계:
24 시간 전: 137
7일 전: 1,166
30일 전: 5,001
전체 시간: 400,339
