주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Jammed 2007 GMC Envoy Tailgate
필요한 것
  1. How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 1 단계, 이미지 3개 중 1개 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 1 단계, 이미지 3개 중 2개 How to Repair a Jammed 2007 GMC Envoy Tailgate, Tailgate Latch Bracket: 1 단계, 이미지 3개 중 3개
    • Use the flat head screwdriver to pry off the small round access panel on the interior of the tailgate.
  2. How to Repair a Jammed 2007 GMC Envoy Tailgate: 2 단계, 이미지 2개 중 1개 How to Repair a Jammed 2007 GMC Envoy Tailgate: 2 단계, 이미지 2개 중 2개
    • Look through the opening and stick your flat head screwdriver underneath this metal arm.
    • Force the arm up. It should stay raised when you pull the screwdriver out.
    • DO NOT USE YOUR FINGER, there is risk of pinching and injury if you do not use the specified tools.
  3. How to Repair a Jammed 2007 GMC Envoy Tailgate: 3 단계, 이미지 3개 중 1개 How to Repair a Jammed 2007 GMC Envoy Tailgate: 3 단계, 이미지 3개 중 2개 How to Repair a Jammed 2007 GMC Envoy Tailgate: 3 단계, 이미지 3개 중 3개
    • Use the flat head screwdriver to push this second lever to the right as far as it will go or until it clicks.
  4. How to Repair a Jammed 2007 GMC Envoy Tailgate: 4 단계, 이미지 2개 중 1개 How to Repair a Jammed 2007 GMC Envoy Tailgate: 4 단계, 이미지 2개 중 2개
    • The tailgate is now unlatched. Open it from the outside.
    • Replace the access panel.
    • If the tailgate will still not open, you most likely did not push the second lever over far enough. Repeat Step 3.
  5. How to Repair a Jammed 2007 GMC Envoy Tailgate: 5 단계, 이미지 2개 중 1개 How to Repair a Jammed 2007 GMC Envoy Tailgate: 5 단계, 이미지 2개 중 2개
    • Inspect the latch bracket's horizontal and vertical bars for dents, warping, and corrosion.
    • If there are no physical defects visible, clean any rust and corrosion and test the tailgate. If it still jams, repeat Steps 1-4 and move on to Step 6.
  6. How to Repair a Jammed 2007 GMC Envoy Tailgate: 6 단계, 이미지 1개 중 1개
    • Use the 40 Torx screwdriver to remove the two T40 63.5 mm screws that secure the latch bracket.
    • Remove the latch from the vehicle.
결론
To reassemble your device, follow these steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 53
전체 시간: 4,555
