주요 콘텐츠로 건너뛰기
How to Repair a Jammed Nozzle on a Perfume Bottle
필요한 것
  1. How to Repair a Jammed Nozzle on a Perfume Bottle, How to Repair a Jammed Nozzle on a Perfume Bottle: 1 단계, 이미지 2개 중 1개 How to Repair a Jammed Nozzle on a Perfume Bottle, How to Repair a Jammed Nozzle on a Perfume Bottle: 1 단계, 이미지 2개 중 2개
    • Remove the nozzle from the bottle by taking the pliers and unscrewing the nozzle counterclockwise.
    • If the bottle is made from glass, untwist the nozzle from the bottle gently and slowly as much as possible to prevent the bottle from being damaged.
  2. How to Repair a Jammed Nozzle on a Perfume Bottle: 2 단계, 이미지 2개 중 1개 How to Repair a Jammed Nozzle on a Perfume Bottle: 2 단계, 이미지 2개 중 2개
    • Using your hand, gently pull out the tube so that the metal ball is exposed.
  3. How to Repair a Jammed Nozzle on a Perfume Bottle: 3 단계, 이미지 2개 중 1개 How to Repair a Jammed Nozzle on a Perfume Bottle: 3 단계, 이미지 2개 중 2개
    • Insert a sewing needle into the opening to adjust the metal ball that is stuck in the spring.
    • The reason why the nozzle of the perfume bottom is jammed is because the metal ball is stuck in the spring. This prevents the pump from retracting. The metal ball is supposed to be directly at the bottom of the spring which allows the pump to retract and the product to protrude out of the bottle when you press down on the nozzle.
  4. How to Repair a Jammed Nozzle on a Perfume Bottle: 4 단계, 이미지 2개 중 1개 How to Repair a Jammed Nozzle on a Perfume Bottle: 4 단계, 이미지 2개 중 2개
    • Using your hands, insert the tube back into the opening.
  5. How to Repair a Jammed Nozzle on a Perfume Bottle: 5 단계, 이미지 2개 중 1개 How to Repair a Jammed Nozzle on a Perfume Bottle: 5 단계, 이미지 2개 중 2개
    • Insert the sewing needle into the small opening to make sure that there is no clogging within the opening.
  6. How to Repair a Jammed Nozzle on a Perfume Bottle: 6 단계, 이미지 1개 중 1개
    • Using the pliers, gently twist the jammed nozzle in a clockwise motion until the pump pops up.
  7. How to Repair a Jammed Nozzle on a Perfume Bottle: 7 단계, 이미지 1개 중 1개
    • Using your hands, screw the nozzle back on to the bottle in a clockwise direction.
  8. How to Repair a Jammed Nozzle on a Perfume Bottle: 8 단계, 이미지 1개 중 1개
    • Test the newly unjammed nozzle to see if the product projects out effectively.
결론
To reassemble the perfume bottle, follow these instructions in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tiera Forde
회원 가입일: 01/20/19
359 평판
안내서 1개를 작성함
댓글 7개
complimenti, bell'articolo!
fabriziostar - 답글
This guide is stupid. BEFORE DOING THIS expose the nozzle and insert a sewing needle directly without removing the entire gasket. Don't cause unnecessary damage as most bottles have crimpted gaskets and are irremovable.
Nelson Bankowitz - 답글
hey stupid dont talk $@$* and do a video. I need to see it,
watchyourtyping -
Thank you so much!
Shadeka - 답글
Thanks now a needle is stuck in the tube
Jake Evens - 답글
댓글 쓰기
조회 통계:
지난 24시간: 124
지난 7일: 643
지난 30일: 2,612
전체 시간: 304,669
