주요 콘텐츠로 건너뛰기
How to Repair a Lensatic Compass
필요한 것
  1. How to Repair a Lensatic Compass, How to Repair a Lensatic Compass: 1 단계, 이미지 1/3 How to Repair a Lensatic Compass, How to Repair a Lensatic Compass: 1 단계, 이미지 2/3 How to Repair a Lensatic Compass, How to Repair a Lensatic Compass: 1 단계, 이미지 3/3
    • Using a Phillips #1 screwdriver, remove the four screws in the bottom of the compass.
  2. How to Repair a Lensatic Compass: 2 단계, 이미지 1/3 How to Repair a Lensatic Compass: 2 단계, 이미지 2/3 How to Repair a Lensatic Compass: 2 단계, 이미지 3/3
    • Use the pocket knife or any flat edge to pop the bottom plate out of the compass.
    • Handle sharp edges with care.
    • Take out the dial break which should look like a small piece of plastic.
  3. How to Repair a Lensatic Compass: 3 단계, 이미지 1/3 How to Repair a Lensatic Compass: 3 단계, 이미지 2/3 How to Repair a Lensatic Compass: 3 단계, 이미지 3/3
    • Remove the inner compass.
  4. How to Repair a Lensatic Compass: 4 단계, 이미지 1/2 How to Repair a Lensatic Compass: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Microfiber Cleaning Cloths
    $3.99
    구매
    • Clean the inside of the outer compass with a microfiber towel.
  5. How to Repair a Lensatic Compass: 5 단계, 이미지 1/3 How to Repair a Lensatic Compass: 5 단계, 이미지 2/3 How to Repair a Lensatic Compass: 5 단계, 이미지 3/3
    • Carefully pop the inside lens off using both thumbs.
  6. How to Repair a Lensatic Compass: 6 단계, 이미지 1/2 How to Repair a Lensatic Compass: 6 단계, 이미지 2/2
    • Take out the floating dial. Just flip the inner compass over.
    • Use a pencil and put some graphite on the inside of the center of the floating dial.
  7. How to Repair a Lensatic Compass: 7 단계, 이미지 1/2 How to Repair a Lensatic Compass: 7 단계, 이미지 2/2
    • Use the edge of the pocket knife to sharpen the needle upwards.
    • Go around the needle and be sure not to push too hard as to create an even worse burr.
  8. How to Repair a Lensatic Compass: 8 단계, 이미지 1/2 How to Repair a Lensatic Compass: 8 단계, 이미지 2/2
    • Put the floating dial back on the needle.
  9. How to Repair a Lensatic Compass: 9 단계, 이미지 1/3 How to Repair a Lensatic Compass: 9 단계, 이미지 2/3 How to Repair a Lensatic Compass: 9 단계, 이미지 3/3
    • Put the inner lens back on the inner compass.
    • Use your thumbs to pull the rubber flush against the inner lens.
    • Be sure to line up the black line of the inner lens with what would be the top of the outer compass.
  10. How to Repair a Lensatic Compass: 10 단계, 이미지 1/1
    • Using small circular motions clean the inner lens.
  11. How to Repair a Lensatic Compass: 11 단계, 이미지 1/3 How to Repair a Lensatic Compass: 11 단계, 이미지 2/3 How to Repair a Lensatic Compass: 11 단계, 이미지 3/3
    • Put the inner compass back inside the outer piece.
    • Make sure that the black line lines up with the top of the compass.
    • Put the dial break, the small plastic piece, back on.
  12. How to Repair a Lensatic Compass: 12 단계, 이미지 1/2 How to Repair a Lensatic Compass: 12 단계, 이미지 2/2
    • Put the plate back on the compass
  13. How to Repair a Lensatic Compass: 13 단계, 이미지 1/3 How to Repair a Lensatic Compass: 13 단계, 이미지 2/3 How to Repair a Lensatic Compass: 13 단계, 이미지 3/3
    • Screw all the screws back in and you are finished.
결승점
Alexis Barrios
회원 가입일: 02/06/20
217 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 71
전체 시간: 3,221
