주요 콘텐츠로 건너뛰기
How to Repair a Loose Rear Bicycle Wheel
필요한 것
  1. How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel, How to Repair a Loose Rear Bicycle Wheel: 1 단계, 이미지 3개 중 3개
    • Loosen the rear axle.
    • Turn the bike around, and loosen the brake arm.
  2. How to Repair a Loose Rear Bicycle Wheel: 2 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 2 단계, 이미지 2개 중 2개
    • Take the chain off the gear and take out the wheel.
  3. How to Repair a Loose Rear Bicycle Wheel: 3 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 3 단계, 이미지 2개 중 2개
    • Assess damage of the dropout and wheel.
  4. How to Repair a Loose Rear Bicycle Wheel: 4 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 4 단계, 이미지 2개 중 2개
    • Properly set the wheel back into dropout and put the chain back on the gear.
  5. How to Repair a Loose Rear Bicycle Wheel: 5 단계, 이미지 2개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 5 단계, 이미지 2개 중 2개
    • Pull on the wheel so that the chain is tight, while tightening the rear axle just enough to hold it in place.
  6. How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel: 6 단계, 이미지 3개 중 3개
    • Check for misalignment or frame rubbing by pedaling without resistance.
  7. How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 1개 How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 2개 How to Repair a Loose Rear Bicycle Wheel: 7 단계, 이미지 3개 중 3개
    • Fully tighten the axle.
    • Turn the bike around.
    • Reattach the brake arm.
결론
작성자
3다른 기여자 명과 함께
Lily Suggs
회원 가입일: 01/31/23
145 평판
안내서 1개를 작성함
UC Davis, Team 4-8, Andersen Winter 2023 UC Davis, Team 4-8, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S4G8
3 회원들
안내서 1개 작성
댓글 한 개
Axle alignment is crooked, which can cause wobbling. Loosen the axle nuts or quick-release skewer, align the wheel, and tighten it securely.
Bruno John - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 23
전체 시간: 1,016
