주요 콘텐츠로 건너뛰기
How to Repair a Metal Bar Fence
필요한 것
  1. How to Repair a Metal Bar Fence, How to Repair a Metal Bar Fence: 1 단계, 이미지 1/3 How to Repair a Metal Bar Fence, How to Repair a Metal Bar Fence: 1 단계, 이미지 2/3 How to Repair a Metal Bar Fence, How to Repair a Metal Bar Fence: 1 단계, 이미지 3/3
    • Use the grinder by doing a back and forth motion to sand down the post. This clears rust buildup and paint that is left on both metal bars.
    • Caution: Use safety glasses while using the grinder to prevent residue from getting in your eyes.
  2. How to Repair a Metal Bar Fence: 2 단계, 이미지 1/3 How to Repair a Metal Bar Fence: 2 단계, 이미지 2/3 How to Repair a Metal Bar Fence: 2 단계, 이미지 3/3
    • Use the grinder to sand down part of the metal fence so the ground clamp on the welding machine has ground to be on for the machine to work.
    • What the ground clamp does is that it provides you with the right voltage that you will need for the metals to actually be welded together. If it isn't a similar metal, the voltage/power of the machine can either be too little or too much.
    • Put the welding ground clamp on the same piece of metal that has also gotten paint removed with the grinder.
  3. How to Repair a Metal Bar Fence: 3 단계, 이미지 1/3 How to Repair a Metal Bar Fence: 3 단계, 이미지 2/3 How to Repair a Metal Bar Fence: 3 단계, 이미지 3/3
    • Warning: use welding gloves and a welding helmet since the brightness can affect your vision and the heat can burn you.
    • Hold both posts together, and use the weld gun by pressing on the trigger it has while moving the tip of the welding gun from one side to the other. Make slow passes of about 4 seconds between both metal posts since the posts are usually thin.
    • The welding pattern I used was just move the weld gun's point from one side to the other in a straight line since it is a really small area you are working on.
  4. How to Repair a Metal Bar Fence: 4 단계, 이미지 1/1
    • Use the wire brush to brush off the area welded and to brush off any paint that can be peeling around the area you welded. If you still need to weld repeat step 3 and after that repeat this step once more.
  5. How to Repair a Metal Bar Fence: 5 단계, 이미지 1/1
    • Use a spray paint can the color of your metal fence to paint the areas welded and the areas that were sanded down.
    • To spray paint shake the can a few times, then start off by spraying from a distance and then getting closer to cover the area more.
  6. How to Repair a Metal Bar Fence: 6 단계, 이미지 1/1
    • The fence should now be welded and painted. If more than one of the posts needs welding, repeat all steps.
결론
To fix your metal fence, follow these instructions in order.
다른 한 분이 해당 안내서를 완성하였습니다.
George Vega
회원 가입일: 01/26/22
160 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-28, Harris Spring 2022 CSU Los Angeles, Team 7-28, Harris Spring 2022 회원
CSULA-HARRIS-S22S7G28
1 회원
안내서 3개 작성하였습니다
댓글 2개
Your information is very interesting. Thanks for posting. The benefits of ***Miller Welding Plant*** Machines are high technology and constant innovation.
Rafeel Clark - 답글
You have provided very helpful information in this Content. An extensive catalog of  Welding Machines, most importantly, It is an essential element for your protection when working.
Jonathan Ryan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 66
전체 시간: 1,543
