주요 콘텐츠로 건너뛰기
How to Repair a Missing Crochet Stitch
필요한 것
  1. How to Repair a Missing Crochet Stitch, How to Repair a Missing Crochet Stitch: 1 단계, 이미지 1개 중 1개
    • Identify where the repair is needed. Locate where the missing stitch should be.
  2. How to Repair a Missing Crochet Stitch: 2 단계, 이미지 1개 중 1개
    • Use the crochet hook to hook through the base stitch, (where the missing stitch should have been located), from front to back.
  3. How to Repair a Missing Crochet Stitch: 3 단계, 이미지 1개 중 1개
    • Create a slip knot with the yarn. Leaving about a 3 inch tail at the end to weave in later.
  4. How to Repair a Missing Crochet Stitch: 4 단계, 이미지 1개 중 1개
    • Loop the slip knot loop over the hook, and pull the yarn through the base stitch
  5. How to Repair a Missing Crochet Stitch: 5 단계, 이미지 1개 중 1개
    • Chain stitch the amount of stitches that the missing stitch should be plus one.
    • So if the missing stitch is a single crochet stitch, chain stitch two stitches, if the missing stitch is a double crochet stitch, chain stitch three stitches, and so on.
  6. How to Repair a Missing Crochet Stitch: 6 단계, 이미지 1개 중 1개
    • Remove the crochet hook and knot the remaining loop. Cut off the yarn leaving another 3 inch tail.
  7. How to Repair a Missing Crochet Stitch: 7 단계, 이미지 1개 중 1개
    • Thread the darning needle with one of the 3 inch tails. It does not matter which one you choose.
    • Caution: Needle is sharp and should be handled carefully to avoid injury.
  8. How to Repair a Missing Crochet Stitch: 8 단계, 이미지 1개 중 1개
    • Begin to weave the tail into the surrounding stitches from front to back.
    • Make sure to split the yarn when weaving, for a more seamless look.
  9. How to Repair a Missing Crochet Stitch: 9 단계, 이미지 1개 중 1개
    • After fully weaving one tail, cut off any excess, and begin weaving the next. Repeating Step 7 through 8.
결론
작성자
1다른 기여자 명과 함께
Rylie Vallo
회원 가입일: 10/11/20
179 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 75
전체 시간: 8,879
