주요 콘텐츠로 건너뛰기
How to Repair a Painting Frame
필요한 것
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 1/3 How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 2/3 How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 3/3
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: 2 단계, 이미지 1/1
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: 3 단계, 이미지 1/1
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: 4 단계, 이미지 1/3 How to Repair a Painting Frame: 4 단계, 이미지 2/3 How to Repair a Painting Frame: 4 단계, 이미지 3/3
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: 5 단계, 이미지 1/3 How to Repair a Painting Frame: 5 단계, 이미지 2/3 How to Repair a Painting Frame: 5 단계, 이미지 3/3
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: 6 단계, 이미지 1/1
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: 7 단계, 이미지 1/2 How to Repair a Painting Frame: 7 단계, 이미지 2/2
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: 8 단계, 이미지 1/1
    • After that, you will have a restored painting frame.
결승점
Sofia Morales
회원 가입일: 10/06/21
157 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 434
