주요 콘텐츠로 건너뛰기
How to Repair a Painting Frame
필요한 것
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 3개 중 1개 How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 3개 중 2개 How to Repair a Painting Frame, How to Repair a Painting Frame: 1 단계, 이미지 3개 중 3개
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: 2 단계, 이미지 1개 중 1개
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: 3 단계, 이미지 1개 중 1개
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: 4 단계, 이미지 3개 중 1개 How to Repair a Painting Frame: 4 단계, 이미지 3개 중 2개 How to Repair a Painting Frame: 4 단계, 이미지 3개 중 3개
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: 5 단계, 이미지 3개 중 1개 How to Repair a Painting Frame: 5 단계, 이미지 3개 중 2개 How to Repair a Painting Frame: 5 단계, 이미지 3개 중 3개
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: 6 단계, 이미지 1개 중 1개
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: 7 단계, 이미지 2개 중 1개 How to Repair a Painting Frame: 7 단계, 이미지 2개 중 2개
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: 8 단계, 이미지 1개 중 1개
    • After that, you will have a restored painting frame.
결승점
작성자
1다른 기여자 명과 함께
Sofia Morales
회원 가입일: 10/06/21
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 797
