주요 콘텐츠로 건너뛰기
How to Repair a Patio Solar Light
필요한 것
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: 1 단계, 이미지 1개 중 1개
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: 2 단계, 이미지 1개 중 1개
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: 3 단계, 이미지 1개 중 1개
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: 4 단계, 이미지 1개 중 1개
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: 5 단계, 이미지 3개 중 1개 How to Repair a Patio Solar Light: 5 단계, 이미지 3개 중 2개 How to Repair a Patio Solar Light: 5 단계, 이미지 3개 중 3개
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: 6 단계, 이미지 1개 중 1개
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
결론
작성자
2다른 기여자 명과 함께
Miguel Antonio Gonzales
회원 가입일: 02/20/24
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 50
전체 시간: 612
