주요 콘텐츠로 건너뛰기
How to Repair a Portable Fan
필요한 것
  1. How to Repair a Portable Fan, How to Repair a Portable Fan: 1 단계, 이미지 2개 중 1개 How to Repair a Portable Fan, How to Repair a Portable Fan: 1 단계, 이미지 2개 중 2개
    • Unplug the power cord before beginning.
    • Loosen the 4 phillips screws around the rim and remove the front of the cage
  2. How to Repair a Portable Fan: 2 단계, 이미지 1개 중 1개
    • Remove the fan blade by loosening the screw on the shaft while pulling up.
    • The screw does not need to be fully removed before the blade will slide free.
  3. How to Repair a Portable Fan: 3 단계, 이미지 1개 중 1개
    • Remove the wiring cover located above the fan motor.
    • There are 2 more screws holding the back mounting plate and cage together. They will be removed in a later step
  4. How to Repair a Portable Fan: 4 단계, 이미지 1개 중 1개
    • Remove the motor from the mounting plate by loosing the 2 smaller screws on the front.
  5. How to Repair a Portable Fan: 5 단계, 이미지 1개 중 1개
    • Remove the final 2 screws holding the mounting plate to the cage.
  6. How to Repair a Portable Fan: 6 단계, 이미지 1개 중 1개
    • Carefully pass the motor through the opening at the back of the cage.
  7. How to Repair a Portable Fan: 7 단계, 이미지 2개 중 1개 How to Repair a Portable Fan: 7 단계, 이미지 2개 중 2개
    • Using an 8mm wrench and phillips screwdriver, remove the magnet mounts from the body of the motor.
    • The magnet will slide out of the motor . Inspect the magnet and motor for anything that may cause a hang-up.
    • Do not over-tighten the magnet mounts during reassembly. Over-tightening may cause the motor to bind.
  8. How to Repair a Portable Fan: 8 단계, 이미지 2개 중 1개 How to Repair a Portable Fan: 8 단계, 이미지 2개 중 2개
    • Clean and lubricate the magnet shaft and mounting brackets
    • Any medium or low viscosity lubricant will do.
결론
To reassemble your device, follow these steps in reverse order.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Isaac MacMillan
회원 가입일: 10/02/17
227 평판
안내서 1개를 작성함
Michigan Tech, Team S5-G11, Galliah Fall 2017 Michigan Tech, Team S5-G11, Galliah Fall 2017 회원
MTU-GALLIAH-F17S5G11
2 회원들
안내서 2개를 작성함
4가이드 댓글
What are the chances the exact fan that I need to repair would be here? I'm about to put it back together… Let's see if it worked! 9/3/19, 10:45 pm.
Clark Nova - 답글
OK. It's back together but the fan doesn't spin. I feel the motor doing… Something. It vibrates softly. So, now to figure out why it's not spinning.
Clark Nova - 답글
hello…my fan wouldn't work until I tilt the head upwards..what could be wrong pls???
adewale ogunbona - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 120
전체 시간: 21,440
