주요 콘텐츠로 건너뛰기
How to Repair a Resin Charm
필요한 것
  1. How to Repair a Resin Charm, How to Repair a Resin Charm: 1 단계, 이미지 1/2 How to Repair a Resin Charm, How to Repair a Resin Charm: 1 단계, 이미지 2/2
    • Fit the broken pieces together with the flattest side of the charm facing towards you.
  2. How to Repair a Resin Charm: 2 단계, 이미지 1/2 How to Repair a Resin Charm: 2 단계, 이미지 2/2
    • Lay a piece of tape on the crack and press down smoothly.
  3. How to Repair a Resin Charm: 3 단계, 이미지 1/1
    • Pick up the pieces so the crack is facing up.
    • Bend the pieces to create a slight gap.
    • CAUTION: Wear gloves when working with resin.
  4. How to Repair a Resin Charm: 4 단계, 이미지 1/2 How to Repair a Resin Charm: 4 단계, 이미지 2/2
    • Add resin to the crack.
    • Press the pieces together.
  5. How to Repair a Resin Charm: 5 단계, 이미지 1/2 How to Repair a Resin Charm: 5 단계, 이미지 2/2
    • Use a cotton swab to spread the resin in the crack.
    • Pick up the excess resin with a cotton swab.
  6. How to Repair a Resin Charm: 6 단계, 이미지 1/3 How to Repair a Resin Charm: 6 단계, 이미지 2/3 How to Repair a Resin Charm: 6 단계, 이미지 3/3
    • Turn on the UV light.
    • Put the charm under the UV light for 120 seconds per side.
    • Remove the charm.
결론
Now your charm is repaired and can once again be worn or displayed!
Jorja
회원 가입일: 04/25/24
133 평판
안내서 1개 작성함
UC Davis, Team 2-7, Whithaus Spring 2024 UC Davis, Team 2-7, Whithaus Spring 2024 회원
UCD-WHITHAUS-S24S2G7
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 21
전체 시간: 42
