주요 콘텐츠로 건너뛰기
How to Repair a Round Head Ratchet
필요한 것
  1. How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: 1 단계, 이미지 1/3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: 1 단계, 이미지 2/3 How to Repair a Round Head Ratchet, How to Repair a Round Head Ratchet: 1 단계, 이미지 3/3
    • Remove the direction selector dial by turning it counterclockwise with a T15 screwdriver.
  2. How to Repair a Round Head Ratchet: 2 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 2 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 2 단계, 이미지 3/3
    • Lift up on the direction selector dial to remove it.
    • Be careful to keep the heart spring in place during removal.
  3. How to Repair a Round Head Ratchet: 3 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 3 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 3 단계, 이미지 3/3
    • Lift up on the heart spring to remove it.
  4. How to Repair a Round Head Ratchet: 4 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 4 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 4 단계, 이미지 3/3
    • Remove the pawl and anvil by sliding them out of the ratchet handle.
  5. How to Repair a Round Head Ratchet: 5 단계, 이미지 1/1
    • Clean all the old grease and dirt off the parts with a rag.
  6. How to Repair a Round Head Ratchet: 6 단계, 이미지 1/2 How to Repair a Round Head Ratchet: 6 단계, 이미지 2/2
    • Lubricate the pawl and the teeth in the head of the ratchet handle with a light coat of multi-purpose grease.
  7. How to Repair a Round Head Ratchet: 7 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 7 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 7 단계, 이미지 3/3
    • Reinstall the anvil and pawl by sliding them into the ratchet handle.
  8. How to Repair a Round Head Ratchet: 8 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 8 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 8 단계, 이미지 3/3
    • Reinstall the heart spring by sliding the end of the spring into the hole in the pawl.
  9. How to Repair a Round Head Ratchet: 9 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 9 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 9 단계, 이미지 3/3
    • Reinstall the direction selector dial, being careful to place the stud on the dial within the loop of the heart spring.
  10. How to Repair a Round Head Ratchet: 10 단계, 이미지 1/3 How to Repair a Round Head Ratchet: 10 단계, 이미지 2/3 How to Repair a Round Head Ratchet: 10 단계, 이미지 3/3
    • Reinstall the direction selector dial screw and tighten in a clockwise direction with a T15 screwdriver.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Lucas
회원 가입일: 10/08/21
229 평판
안내서 1개 작성함
University of Memphis, Team 51-2, Willis Fall 2021 University of Memphis, Team 51-2, Willis Fall 2021 회원
UM-WILLIS-F21S51G2
1 회원
안내서 2개 작성하였습니다
댓글 한 개
Very clear and accurate, especially for the spring shape and its positioning in installation, which helped me to fix the problem with it.
Jason Zou - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 35
30일 전: 167
전체 시간: 1,789
