주요 콘텐츠로 건너뛰기
How to Repair a Scratched CD
필요한 것
  1. How to Repair a Scratched CD, How to Repair a Scratched CD: 1 단계, 이미지 1/1
    • Rinse the disc with water and wipe clean to remove any dust or dirt.
  2. How to Repair a Scratched CD: 2 단계, 이미지 1/3 How to Repair a Scratched CD: 2 단계, 이미지 2/3 How to Repair a Scratched CD: 2 단계, 이미지 3/3
    • Apply a rubbing compound, moving from the center of the disc outwards.
    • Use enough force to create a mirror polished surface when rubbing compound application is complete.
    • We found that applying the rubbing compound for at least 30 seconds to 1 minute is sufficient.
  3. How to Repair a Scratched CD: 3 단계, 이미지 1/1
    • Let the CD sit for 5 minutes.
  4. How to Repair a Scratched CD: 4 단계, 이미지 1/2 How to Repair a Scratched CD: 4 단계, 이미지 2/2
    • Wipe the CD clean with a new rag, removing any excess compound.
  5. How to Repair a Scratched CD: 5 단계, 이미지 1/3 How to Repair a Scratched CD: 5 단계, 이미지 2/3 How to Repair a Scratched CD: 5 단계, 이미지 3/3
    • Apply a thin coat of car wax directly to the CD, using a circular application method.
    • Apply in either small circular motions or large motions that follow the circumference of the disc.
  6. How to Repair a Scratched CD: 6 단계, 이미지 1/2 How to Repair a Scratched CD: 6 단계, 이미지 2/2
    • Wipe the CD clean, removing any excess wax.
결론
Congratulations! You have successfully repaired the scratched CD!
다른 6명이 해당 안내서를 완성하였습니다.
Emma Larson
회원 가입일: 09/20/16
283 평판
안내서 1개 작성함
University of Minnesota, Team 1-3, Breuch Fall 2016 University of Minnesota, Team 1-3, Breuch Fall 2016 회원
UMN-BREUCH-F16S1G3
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 60
30일 전: 233
전체 시간: 11,720
