주요 콘텐츠로 건너뛰기
How to Repair a Seam Split in a Sleeping Bag
필요한 것
  1. How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: 1 단계, 이미지 2개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Identify the repair area: 1 단계, 이미지 2개 중 2개
    • Locate the seam split that needs to be fixed.
  2. How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: 2 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: 2 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Sleeping Bag, Prepare for stitching: 2 단계, 이미지 3개 중 3개
    • Find a matching color thread and prepare the needle.
    • Make a double thread and add a little knot at the end.
  3. How to Repair a Seam Split in a Sleeping Bag, Start stitching: 3 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Start stitching: 3 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Sleeping Bag, Start stitching: 3 단계, 이미지 3개 중 3개
    • Make sure that the needle is in a position that is perpendicular to the edge of the seam (red arrow).
    • Take turns going up and down following line of the seam.
    • Note For this example we are doing an "invisible" stitch that provides a subtle solution to the split.
  4. How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: 4 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: 4 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Sleeping Bag, Secure the stitch: 4 단계, 이미지 3개 중 3개
    • Secure the stitch by pulling the thread tighter as you go.
    • Continue until you reach the end of the split.
  5. How to Repair a Seam Split in a Sleeping Bag, Clean the area: 5 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Clean the area: 5 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Sleeping Bag, Clean the area: 5 단계, 이미지 3개 중 3개
    • Add a knot at the end of the stitch.
    • Use a pair of scissors to clean the loose threads.
  6. How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: 6 단계, 이미지 2개 중 1개 How to Repair a Seam Split in a Sleeping Bag, Finished and ready!: 6 단계, 이미지 2개 중 2개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 294
