주요 콘텐츠로 건너뛰기
How to Repair a Seam Split in a Winter Glove
필요한 것
  1. How to Repair a Seam Split in a Winter Glove, Identify the repair area: 1 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Identify the repair area: 1 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Identify the repair area: 1 단계, 이미지 3개 중 3개
    • Locate the seam split that needs to be fixed.
    • Collect all the tools needed for the repair.
  2. How to Repair a Seam Split in a Winter Glove, Prepare the glove: 2 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Prepare the glove: 2 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Prepare the glove: 2 단계, 이미지 3개 중 3개
    • Turn the glove "inside-out" to make the stitching in the next steps easier.
  3. How to Repair a Seam Split in a Winter Glove, Prepare for stitching: 3 단계, 이미지 2개 중 1개 How to Repair a Seam Split in a Winter Glove, Prepare for stitching: 3 단계, 이미지 2개 중 2개
    • Insert the thread into the needle and make a small knot in the end.
    • Note: For this fix the repair is going to be "invisible" so it does matter the color of thread you choose.
  4. How to Repair a Seam Split in a Winter Glove, Start stitching: 4 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Start stitching: 4 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Start stitching: 4 단계, 이미지 3개 중 3개
    • If the hole starts where the green arrow is, you should start stitching approximately 5 mm away from the start of the hole (red arrow).
  5. How to Repair a Seam Split in a Winter Glove, Continue stitching: 5 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Continue stitching: 5 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Continue stitching: 5 단계, 이미지 3개 중 3개
    • Continue stitching until you covered the entire whole.
    • Tip: Always insert the needle back through the same side it came out from.
  6. How to Repair a Seam Split in a Winter Glove, Clean the area: 6 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Clean the area: 6 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Clean the area: 6 단계, 이미지 3개 중 3개
    • Finish the fix with a knot at the end and cut excess thread with a pair of scissors.
  7. How to Repair a Seam Split in a Winter Glove, Finished and ready!: 7 단계, 이미지 3개 중 1개 How to Repair a Seam Split in a Winter Glove, Finished and ready!: 7 단계, 이미지 3개 중 2개 How to Repair a Seam Split in a Winter Glove, Finished and ready!: 7 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 30
전체 시간: 107
