주요 콘텐츠로 건너뛰기
How to Repair a Silent Wall Clock Mechanism
필요한 것
  1. How to Repair a Silent Wall Clock Mechanism, How to Repair a Silent Wall Clock Mechanism: 1 단계, 이미지 1개 중 1개
    • Using a screwdriver, remove all the screws on the back of the clock.
  2. How to Repair a Silent Wall Clock Mechanism: 2 단계, 이미지 1개 중 1개
    • Use your fingers to pry up one end of the battery and remove it from the clock.
  3. How to Repair a Silent Wall Clock Mechanism: 3 단계, 이미지 1개 중 1개
    • Clean the battery terminals in the battery compartment using isopropyl alcohol and a cotton swab.
  4. How to Repair a Silent Wall Clock Mechanism: 4 단계, 이미지 1개 중 1개
    • Dry the battery terminals with a clean cloth or paper towels so the terminals are not wet when a new battery is being inserted.
  5. How to Repair a Silent Wall Clock Mechanism: 5 단계, 이미지 1개 중 1개
    • Once the terminals have dried up, remove the glass lens covering the faceplate of the clock to make any adjustments.
  6. How to Repair a Silent Wall Clock Mechanism: 6 단계, 이미지 1개 중 1개
    • Turn the display face up, ensuring the clock hands do not touch each other.
    • Correct the time by moving the hands of the clock and inserting the new battery.
  7. How to Repair a Silent Wall Clock Mechanism: 7 단계, 이미지 1개 중 1개
    • Put the faceplate back on and assemble all of the pieces of the clock.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mohammad Kijera
회원 가입일: 02/01/22
250 평판
안내서 1개를 작성함
York University, Team 1-15, O'Regan Winter 2022 York University, Team 1-15, O'Regan Winter 2022 회원
YORK-O'REGAN-W22S1G15
1 회원
안내서 3개를 작성함
2가이드 댓글
catellano por favor.gracias.
mario oscar Fiori - 답글
You don't need to open the clock to set the time - just turn that circle dial on the backside of the clock! What is this guide "fixing" anyway??
Ari - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 31
지난 30일: 146
전체 시간: 7,781
