주요 콘텐츠로 건너뛰기
How to Repair a Small Hole in Your Clothing
필요한 것
  1. How to Repair a Small Hole in Your Clothing, How to Repair a Small Hole in Your Clothing: 1 단계, 이미지 1/1
    • Grab the clothing you want to fix and lay it on a table.
  2. How to Repair a Small Hole in Your Clothing: 2 단계, 이미지 1/1
    • Find the thread that matches the colour of the clothing you are going to repair.
    • Measure and cut a piece of string a minimum of 20x the length of the hole.
  3. How to Repair a Small Hole in Your Clothing: 3 단계, 이미지 1/3 How to Repair a Small Hole in Your Clothing: 3 단계, 이미지 2/3 How to Repair a Small Hole in Your Clothing: 3 단계, 이미지 3/3
    • Insert the thread through the eye of the needle.
  4. How to Repair a Small Hole in Your Clothing: 4 단계, 이미지 1/3 How to Repair a Small Hole in Your Clothing: 4 단계, 이미지 2/3 How to Repair a Small Hole in Your Clothing: 4 단계, 이미지 3/3
    • Pull the thread through until the length of both ends of the thread are the same length.
    • Tie the ends in a double knot.
  5. How to Repair a Small Hole in Your Clothing: 5 단계, 이미지 1/3 How to Repair a Small Hole in Your Clothing: 5 단계, 이미지 2/3 How to Repair a Small Hole in Your Clothing: 5 단계, 이미지 3/3
    • Pinch the fabric to close the hole, and weave the needle back and forth through the pinch until the hole is sealed.
  6. How to Repair a Small Hole in Your Clothing: 6 단계, 이미지 1/2 How to Repair a Small Hole in Your Clothing: 6 단계, 이미지 2/2
    • Cut the thread from the needle and cut the leftover thread on both ends of the sealed hole.
  7. How to Repair a Small Hole in Your Clothing: 7 단계, 이미지 1/1
    • The hole is completely sealed!
결승점
Ann
회원 가입일: 09/19/20
145 평판
안내서 1개 작성함
York University, Team S3-G66, Melo-Thaiss Fall 2020 York University, Team S3-G66, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S3G66
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 47
30일 전: 197
전체 시간: 5,108
