주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Small Hole in a Spanish Knife Textured Wall
필요한 것
    1. How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: 1 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: 1 단계, 이미지 2개 중 2개
      • Remove any debris from the hole in the wall.
      댓글 쓰기
    2. How to Repair a Small Hole in a Spanish Knife Textured Wall: 2 단계, 이미지 1개 중 1개
      • Scoop some DryDex Spackling on to your plastic taping knife.
      댓글 쓰기
    3. How to Repair a Small Hole in a Spanish Knife Textured Wall: 3 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 3 단계, 이미지 2개 중 2개
      • Fill the hole with spackle.
      댓글 쓰기
    4. How to Repair a Small Hole in a Spanish Knife Textured Wall: 4 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 4 단계, 이미지 2개 중 2개
      • Gently move the taping knife over the newly covered hole in multiple directions.
      • This will ensure the spackle completely fills the hole.
      • Let the DryDex Spackle dry.
      • You will know the spackle is dry when it turns from pink to white.
      댓글 쓰기
    5. How to Repair a Small Hole in a Spanish Knife Textured Wall: 5 단계, 이미지 1개 중 1개
      • Sand the newly spackled area down until the spackle is level with the original wall.
      댓글 쓰기
    6. How to Repair a Small Hole in a Spanish Knife Textured Wall: 6 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 6 단계, 이미지 2개 중 2개
      • Scoop some All Purpose Joint Compound on to your putty knife.
      댓글 쓰기
    7. How to Repair a Small Hole in a Spanish Knife Textured Wall: 7 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 7 단계, 이미지 2개 중 2개
      • Smooth the joint compound on the wall, covering the area you want to re-texture.
      댓글 쓰기
    8. How to Repair a Small Hole in a Spanish Knife Textured Wall: 8 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 8 단계, 이미지 2개 중 2개
      • Gently drag the putty knife through the joint compound to create ridges.
      • Creating ridges is a creative and unique process. You get to decide how close you want the ridges together and at what angle to make the ridges.
      • Let the joint compound completely dry.
      • You will know the Joint Compound is dry when it turns from grey to white.
      댓글 쓰기
    9. How to Repair a Small Hole in a Spanish Knife Textured Wall: 9 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 9 단계, 이미지 2개 중 2개
      • Mix the paint that you have leftover from the first time you painted the wall.
      댓글 쓰기
    10. How to Repair a Small Hole in a Spanish Knife Textured Wall: 10 단계, 이미지 2개 중 1개 How to Repair a Small Hole in a Spanish Knife Textured Wall: 10 단계, 이미지 2개 중 2개
      • Paint the section of the wall that you re-textured.
      • Paint each ridge.
      • Let the paint completely dry.
      댓글 쓰기
결론
You’ve successfully spackled, textured, and painted. Your wall is now as good as new!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kayla Elder
회원 가입일: 09/22/21
228 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 88
전체 시간: 2,808
