주요 콘텐츠로 건너뛰기
How to Repair a Squier Affinity Stratocaster Guitar Jack
필요한 것
  1. How to Repair a Squier Affinity Stratocaster Guitar Jack, Input Jack: 1 단계, 이미지 1/1
    • Test the sound output via amplifier, and then set it to zero.
    • Keeping the amplifier on with the guitar connected to it may produce unpleasant static depending on how loose the jack is. Make sure to turn it off before proceeding.
  2. How to Repair a Squier Affinity Stratocaster Guitar Jack: 2 단계, 이미지 1/1
    • Using the Phillips #3 screwdriver, remove the two 1.2 mm screws that are connected to the plate.
  3. How to Repair a Squier Affinity Stratocaster Guitar Jack: 3 단계, 이미지 1/1
    • Remove the plate without touching the jack.
    • Fixing the jack without removing the plate can cause broken wires. Do not tighten the bolt connecting the jack before taking off the plate.
  4. How to Repair a Squier Affinity Stratocaster Guitar Jack: 4 단계, 이미지 1/3 How to Repair a Squier Affinity Stratocaster Guitar Jack: 4 단계, 이미지 2/3 How to Repair a Squier Affinity Stratocaster Guitar Jack: 4 단계, 이미지 3/3
    • Take the jack out of the guitar.
    • Here, you can examine the wires and check for any interior damages.
  5. How to Repair a Squier Affinity Stratocaster Guitar Jack: 5 단계, 이미지 1/1
    • Carefully tighten the outside of the jack using a wrench.
    • If you do not have an adjustable wrench, use an ESP Multi Spanner.
  6. How to Repair a Squier Affinity Stratocaster Guitar Jack: 6 단계, 이미지 1/1
    • Carefully reconnect the plate back on using your screwdriver.
  7. How to Repair a Squier Affinity Stratocaster Guitar Jack: 7 단계, 이미지 1/1
    • Readjust the output settings on your guitar, and plug in your audio cable.
  8. How to Repair a Squier Affinity Stratocaster Guitar Jack: 8 단계, 이미지 1/1
    • Test the tightness of your input jack before plugging your audio cable into your amplifier.
  9. How to Repair a Squier Affinity Stratocaster Guitar Jack: 9 단계, 이미지 1/1
    • Plug the guitar into the amplifier to test the audio cable sensitivity and output quality.
결론
That is all you need to do to fix your Squier Affinity Stratocaster’s input jack. Now have fun making music!
다른 3명이 해당 안내서를 완성하였습니다.
Maryam Ahmed
회원 가입일: 05/12/21
273 평판
안내서 1개 작성함
York University, Team S1-G2, Melo-Thaiss Summer 2021 York University, Team S1-G2, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G2
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 32
30일 전: 102
전체 시간: 2,884
