주요 콘텐츠로 건너뛰기
How to Repair a Stuck Car Door Latch
필요한 것
  1. How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: 1 단계, 이미지 1/2 How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: 1 단계, 이미지 2/2
    • On the car door that will not close, examine the door latch located near the handle on the side of the door.
    • The car door latch will be locked in a closed position.
  2. How to Repair a Stuck Car Door Latch: 2 단계, 이미지 1/3 How to Repair a Stuck Car Door Latch: 2 단계, 이미지 2/3 How to Repair a Stuck Car Door Latch: 2 단계, 이미지 3/3
    • Position a screwdriver between the legs of the locked door latch.
    • You may use any size screwdriver that will fit between the latch.
  3. How to Repair a Stuck Car Door Latch: 3 단계, 이미지 1/1
    • Pull the exterior car door handle.
  4. How to Repair a Stuck Car Door Latch: 4 단계, 이미지 1/2 How to Repair a Stuck Car Door Latch: 4 단계, 이미지 2/2
    • While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
  5. How to Repair a Stuck Car Door Latch: 5 단계, 이미지 1/3 How to Repair a Stuck Car Door Latch: 5 단계, 이미지 2/3 How to Repair a Stuck Car Door Latch: 5 단계, 이미지 3/3
    • Use the screwdriver to push the latch upwards into the final unlocked position.
  6. How to Repair a Stuck Car Door Latch: 6 단계, 이미지 1/2 How to Repair a Stuck Car Door Latch: 6 단계, 이미지 2/2
    • Close the car door to ensure the latch has been properly reset.
결승점
다른 11명이 해당 안내서를 완성하였습니다.
Kennedy Coleman
회원 가입일: 04/29/20
439 평판
안내서 1개 작성함
UW Tacoma, Team S1-G30, Cardinal Spring 2020 UW Tacoma, Team S1-G30, Cardinal Spring 2020 회원
UWT-CARDINAL-S20S1G30
1 회원
안내서 5개 작성하였습니다
댓글 14개
Thanks a lot, you have saved me from one !&&* of a problem!
dee Knight - 답글
This helped me so much!! Thank you!!!
Jasmine Roman - 답글
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Bill Smith - 답글
Thank you so much! I figured it out because of this post!
Sharan Sahota - 답글
I love this solution. It literally just saved me. Thank you soo much.
Edith Turkson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 165
7일 전: 1,267
30일 전: 5,858
전체 시간: 108,181
