주요 콘텐츠로 건너뛰기
How to Repair a Stuck Toilet Handle
필요한 것
  1. How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: 1 단계, 이미지 1/2 How to Repair a Stuck Toilet Handle, How to Repair a Stuck Toilet Handle: 1 단계, 이미지 2/2
    • Find the shut off valve behind the toilet.
    • To close the shut off valve, most toilet valves need to be turned to the left.
  2. How to Repair a Stuck Toilet Handle: 2 단계, 이미지 1/2 How to Repair a Stuck Toilet Handle: 2 단계, 이미지 2/2
    • Remove the lid from the tank of your toilet.
    • Find the nut inside of the tank that holds your toilet’s lever.
  3. How to Repair a Stuck Toilet Handle: 3 단계, 이미지 1/1
    • Using your hand or an appropriately sized wrench, loosen the nut a little.
    • If your toilet handle is still sticking, move to the next step.
  4. How to Repair a Stuck Toilet Handle: 4 단계, 이미지 1/1
    • Push the handle down slowly and watch the lever arm to make sure it is not touching anything.
    • The lever arm of your toilet handle cannot touch anything or else it might cause the handle to stick.
  5. How to Repair a Stuck Toilet Handle: 5 단계, 이미지 1/2 How to Repair a Stuck Toilet Handle: 5 단계, 이미지 2/2
    • If your toilet’s lever arm is touching something, bend the metal so that this does not happen.
  6. How to Repair a Stuck Toilet Handle: 6 단계, 이미지 1/2 How to Repair a Stuck Toilet Handle: 6 단계, 이미지 2/2
    • If your toilet’s lever arm is catching on the chain which connects it to the flapper at the bottom of the tank, then this will need to be remedied.
    • The length of the toilet chain can be adjusted by moving the hook a few links down and reattaching it to the lever.
결론
To reassemble your toilet, turn the water valve back on and put the lid back on.
Anna Pettit
회원 가입일: 03/17/21
148 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 33
전체 시간: 819
