이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the trailer jack from trailer.
Use a 19mm box end wrench to remove the 19mm hex head bolt that secures the jack to the trailer.
Slide the jack off the trailer to remove.
Remove the nut and bolt that secures the handle to the jack.
Use two half-inch box end wrenches to remove the half-inch bolt and nut.
Slide the handle upward after removing the nut and bolt to remove the handle.
Set the handle aside.
Turn the jack upside down and use a hammer to gently slide the upper assembly off the lower assembly.
Set the upper assembly aside.
Begin to remove the rust and corrosion using a die-grinder and steel wire wheel.
Remove rust and corrosion from the upper and lower assemblies of the jack using a die-grinder and sanding pad.
Paint the upper and lower assemblies for prevention of future rust and corrosion.
During re-assembly, align the notch on the upper assembly to the grove on the lower assembly.
Install the washer and the jack handle over the stud of the jack.
Insert the bolt through the handle and the hole located on the stud.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you, very helpful. our tongue jack was a bit different looking but the principles were all the same, and with the help of this guide we got it fixed.
