주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
How to Repair a Stuck or Broken Chainsaw Rope
필요한 것
  1. How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 1 단계, 이미지 2개 중 1개 How to Repair a Stuck or Broken Chainsaw Rope, How to Repair a Stuck or Broken Chainsaw Rope: 1 단계, 이미지 2개 중 2개
    • Remove the chainsaw casing or handle.
    • This step will vary depending on what kind of chainsaw you are using. Some might only require you to remove the handle, while others have a casing you must remove instead.
  2. How to Repair a Stuck or Broken Chainsaw Rope: 2 단계, 이미지 1개 중 1개
    • Remove the screw on top of the housing.
  3. How to Repair a Stuck or Broken Chainsaw Rope: 3 단계, 이미지 2개 중 1개 How to Repair a Stuck or Broken Chainsaw Rope: 3 단계, 이미지 2개 중 2개
    • Remove the housing unit.
  4. How to Repair a Stuck or Broken Chainsaw Rope: 4 단계, 이미지 2개 중 1개 How to Repair a Stuck or Broken Chainsaw Rope: 4 단계, 이미지 2개 중 2개
    • Remove the rope from the chainsaw using a pair of pliers.
  5. How to Repair a Stuck or Broken Chainsaw Rope: 5 단계, 이미지 1개 중 1개
    • Make your adjustments to fix any problems with the rope.
    • The adjustments needed to be made will vary depending on your specific problem with the rope.
  6. How to Repair a Stuck or Broken Chainsaw Rope: 6 단계, 이미지 1개 중 1개
    • Stick the rope back through the insertion hole.
  7. How to Repair a Stuck or Broken Chainsaw Rope: 7 단계, 이미지 1개 중 1개
    • Stick the housing back onto the casing.
    • Do not screw the housing on yet.
  8. How to Repair a Stuck or Broken Chainsaw Rope: 8 단계, 이미지 1개 중 1개
    • Twist the housing unit until the tension is maxed out.
    • Caution: Once the tension is maxed out, you must hold the housing unit firmly or else it will slide out and possibly hit you or someone nearby.
  9. How to Repair a Stuck or Broken Chainsaw Rope: 9 단계, 이미지 2개 중 1개 How to Repair a Stuck or Broken Chainsaw Rope: 9 단계, 이미지 2개 중 2개
    • Stick the rope through the groove into the housing.
  10. How to Repair a Stuck or Broken Chainsaw Rope: 10 단계, 이미지 1개 중 1개
    • Re-tie the rope into a knot.
  11. How to Repair a Stuck or Broken Chainsaw Rope: 11 단계, 이미지 2개 중 1개 How to Repair a Stuck or Broken Chainsaw Rope: 11 단계, 이미지 2개 중 2개
    • Slowly rewind the housing unit until the rope is back into its original position.
  12. How to Repair a Stuck or Broken Chainsaw Rope: 12 단계, 이미지 1개 중 1개
    • Re-screw any screws used to take off the housing.
    • This step will vary. Not all chainsaws will have extra screws on their housing unit.
  13. How to Repair a Stuck or Broken Chainsaw Rope: 13 단계, 이미지 1개 중 1개
    • Place the casing or handle back onto the chainsaw.
    • Similarly to Step 1, this will vary depending on the type of chainsaw you are using.
  14. How to Repair a Stuck or Broken Chainsaw Rope: 14 단계, 이미지 1개 중 1개
    • Pull on the rope to make sure the chainsaw works.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Whetzel
회원 가입일: 02/22/21
265 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 41
전체 시간: 886
