주요 콘텐츠로 건너뛰기
How to Repair a Tear in a Camping Chair
필요한 것
  1. How to Repair a Tear in a Camping Chair, Identify the repair area: 1 단계, 이미지 2개 중 1개 How to Repair a Tear in a Camping Chair, Identify the repair area: 1 단계, 이미지 2개 중 2개
    • Locate the tear that needs to be fixed.
  2. How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Unscrew the back of the chair: 2 단계, 이미지 3개 중 3개
    • Use a screwdriver to disassemble the chair and then remove the parts piece by piece.
  3. How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: 3 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: 3 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Disassemble the rest of the chair: 3 단계, 이미지 3개 중 3개
    • Continue to take the pieces and set them aside until you reach the fabric that needs to be stitched.
    • In this step, you simply need to use your hands to slide off and gently remove each part.
  4. How to Repair a Tear in a Camping Chair, Organize the repair area: 4 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Organize the repair area: 4 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Organize the repair area: 4 단계, 이미지 3개 중 3개
    • Set aside all the components of the chair, sort them out in small groups and prepare for stitching.
  5. How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: 5 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: 5 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Prepare the piece of cloth: 5 단계, 이미지 3개 중 3개
    • Use a pair of scissors to cut a piece of cloth.
    • Note: we recommend using a piece of cloth that matches the material of the torn fabric. In this example, we used a non-stretch fabric that had a similar texture and feel to the original.
    • Place the cloth underneath the tear and get ready for the next step.
  6. How to Repair a Tear in a Camping Chair, Prepare for stitching: 6 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Prepare for stitching: 6 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Prepare for stitching: 6 단계, 이미지 3개 중 3개
    • Use sewing pins to fix the piece of cloth in place. Put the pins around the tear, forming a "square" shape (green lines).
  7. How to Repair a Tear in a Camping Chair, Start sewing: 7 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Start sewing: 7 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Start sewing: 7 단계, 이미지 3개 중 3개
    • Use a straight stitch to sew a "square shape" around the tear.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Rotate the piece as much as you need to find the position that makes the stitching more comfortable.
    • Once you have completed the stitch, use a pair of scissors to clean the loose threads.
  8. How to Repair a Tear in a Camping Chair, Reinforce the stitch: 8 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Reinforce the stitch: 8 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Reinforce the stitch: 8 단계, 이미지 3개 중 3개
    • Adjust the sewing machine to the Zig-Zag stitch setting and the length to "3".
    • Stitch a diagonal line following the direction of the red arrow.
  9. How to Repair a Tear in a Camping Chair, Clean the area: 9 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Clean the area: 9 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Clean the area: 9 단계, 이미지 3개 중 3개
    • Use a pair of scissors to cut the loose parts around the stitch and clean the area.
  10. How to Repair a Tear in a Camping Chair, Reassemble the chair: 10 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Reassemble the chair: 10 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Reassemble the chair: 10 단계, 이미지 3개 중 3개
    • Start by putting the components back, first the repaired fabric and then the rest of the parts.
    • Screw back the pieces that were taken on the previous steps.
  11. How to Repair a Tear in a Camping Chair, Finished and ready!: 11 단계, 이미지 3개 중 1개 How to Repair a Tear in a Camping Chair, Finished and ready!: 11 단계, 이미지 3개 중 2개 How to Repair a Tear in a Camping Chair, Finished and ready!: 11 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 34
전체 시간: 573
