이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Feeling torn as to whether or not you have the skills to repair a blown-out seam in your garment? Fear not. This guide will show you how to repair a rip along a straight seam. In this guide we'll be using contrasting thread for visibility. When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
필요한 것
Examine the damaged seam in your garment, checking for tears and removing any loose threads.
Open the garment as much as possible, laying the seam flat.
Check your alignment and make sure the two edges of your fabric line up.
Put the garment in the machine, starting a few inches before the torn seam to overlap with the stitches.
Drop the presser foot. Align the first line of stitches with the needle.
Some clothes have two rows of stitching, If your garment does, reposition it in the sewing machine. Drop the needle into the second line of stitches at about where you began sewing your previous seam.
Repeat steps 3-7 of this guide to resew the second line of stitches.
If your garment only has a single line of stitches, skip this step and proceed to the next step.
다른 2명이 해당 안내서를 완성하였습니다.
