주요 콘텐츠로 건너뛰기
How to Repair a Torn Stuffed Animal
필요한 것
  1. How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 1 단계, 이미지 1/3 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 1 단계, 이미지 2/3 How to Repair a Torn Stuffed Animal, How to Repair a Torn Stuffed Animal: 1 단계, 이미지 3/3
    • Gather all of your materials.
    • Pinpoint the tear in your stuffed animal.
    • Measure out the desired length of thread that will fully cover your tear.
    • The amount of thread that you use will vary depending on the size of the hole. However, it is always better to use too much thread rather than too little.
  2. How to Repair a Torn Stuffed Animal: 2 단계, 이미지 1/1
    • Push the thread through the hole of the needle. Make sure to pull the thread all the way through.
    • Working with needles can be dangerous.
  3. How to Repair a Torn Stuffed Animal: 3 단계, 이미지 1/2 How to Repair a Torn Stuffed Animal: 3 단계, 이미지 2/2
    • Take both of the threads and match up their ends.
    • Double knot the two ends together.
  4. How to Repair a Torn Stuffed Animal: 4 단계, 이미지 1/1
    • Cut off any excess thread at the end of the double knot.
  5. How to Repair a Torn Stuffed Animal: 5 단계, 이미지 1/1
    • Bring the sewing needle to the top of the tear in the fabric.
    • Push the needle in through the interior of the fabric.
    • Putting the needle on the inside of the fabric hides the knot.
  6. How to Repair a Torn Stuffed Animal: 6 단계, 이미지 1/3 How to Repair a Torn Stuffed Animal: 6 단계, 이미지 2/3 How to Repair a Torn Stuffed Animal: 6 단계, 이미지 3/3
    • Begin stitching up the tear. Bring the needle from the starting side over to the other side of the tear.
    • Push the thread through the top of the fabric.
    • Bring the needle back over to the starting side and pull it back up through the interior of the fabric once more.
  7. How to Repair a Torn Stuffed Animal: 7 단계, 이미지 1/1
    • Continue stitching up the tear until you reach the end of the tear.
  8. How to Repair a Torn Stuffed Animal: 8 단계, 이미지 1/1
    • On your final stitch, pull the needle and thread through the loop.
    • Repeat this step once more to make sure your knot is secure.
    • Pull the needle tight.
    • Don't pull the needle too tight so that you break your thread.
  9. How to Repair a Torn Stuffed Animal: 9 단계, 이미지 1/1
    • Cut the end of the thread once the knot has been secured.
결승점
다른 47명이 해당 안내서를 완성하였습니다.
Gracie Campbell
회원 가입일: 09/29/15
1,551 평판
안내서 1개 작성함
Cal Poly, Team 17-5, Green Fall 2015 Cal Poly, Team 17-5, Green Fall 2015 회원
CPSU-GREEN-F15S17G5
4 회원들
안내서 11개 작성하였습니다
댓글 10개
I have a vintage Mickey Mouse (1970s) he has red velvet shorts with yellow felt buttons. It looks like they were just attached by adhesive when made. One of the buttons have been lost due to time and left a bare patch of velvet. I am unable to find hints or suggestions on how to repair our Mickey. It was my husband's as a child and our youngest was in love with it until the button disappeared. He wont play with it now because he think he hurt it. Any help would be greatly appreciated.
Heidi Carstens - 답글
You could sew on Another button, I'm sure you could find a very similar button on Amazon and quickly thread it back together, good as new. If you need any more help, just let me know :)
Zara Hunt -
How about you try to make a duplicate button and sew it on to your Mickey. You can probably make one by cutting two pieces of yellow felt fabric and sewing them together, you can then sem the button on Mickey where the bare patch is. If it looks awkward, then you can make another button and replace it with the other (original) button if it looks different from the new one you made. You can always make a new button, but maybe not an original one.
By doing this repair, you might take some of the vintageness out of Mickey, but your son would be happy and play with him again. Which is more important? Don’t forget the reason why Mickey was made in the first place. You'll be restoring Mickey’s purpose of being played by children again!
Omar Farid - 답글
Simple and easy to follow instructions! Thank you so much!
I’m still only learning to sew, and a dog we were looking after decided to chew on my little sister’s FAVOURITE unicorn stuffy, and left a HUGE tear in it. Searched for ages to find instructions on how to sew it back up, but they were all extremely complicated, overdone, or way too confusing to follow. This one, however, was amazing! I was able to fix it for her like new! Thank you!
Maddy Smith - 답글
I have a Large Fireman Sam Plushie and between the feet and the legs the stuffed toy is ripped. What should I do?
Fireman Sam UK - 답글
댓글 쓰기
조회 통계:
24 시간 전: 34
7일 전: 203
30일 전: 829
전체 시간: 127,802
