주요 콘텐츠로 건너뛰기
How to Repair a Velcro Strap in a Sleeping Bag
필요한 것
  1. How to Repair a Velcro Strap in a Sleeping Bag, Identify the repair area: 1 단계, 이미지 2개 중 1개 How to Repair a Velcro Strap in a Sleeping Bag, Identify the repair area: 1 단계, 이미지 2개 중 2개
    • Locate the velcro strap that needs to be fixed.
    • Use a pair of scissors to clean the loose threads in the area.
  2. How to Repair a Velcro Strap in a Sleeping Bag, Pin the area: 2 단계, 이미지 2개 중 1개 How to Repair a Velcro Strap in a Sleeping Bag, Pin the area: 2 단계, 이미지 2개 중 2개
    • Pin the velcro in the right position and make sure that it is holding both the front and back side (red circle).
  3. How to Repair a Velcro Strap in a Sleeping Bag, Stitch the velcro strap: 3 단계, 이미지 3개 중 1개 How to Repair a Velcro Strap in a Sleeping Bag, Stitch the velcro strap: 3 단계, 이미지 3개 중 2개 How to Repair a Velcro Strap in a Sleeping Bag, Stitch the velcro strap: 3 단계, 이미지 3개 중 3개
    • Use a straight stitch to sew along the patch.
    • Tip: For tips on setting up the machine take a look at this iFixit guide.
    • Rotate the sleeping bag as much as you need to find the position that makes the stitching more comfortable.
  4. How to Repair a Velcro Strap in a Sleeping Bag, Clean the area: 4 단계, 이미지 3개 중 1개 How to Repair a Velcro Strap in a Sleeping Bag, Clean the area: 4 단계, 이미지 3개 중 2개 How to Repair a Velcro Strap in a Sleeping Bag, Clean the area: 4 단계, 이미지 3개 중 3개
    • Use a pair of scissors to clean the loose threads in both the front and back side.
  5. How to Repair a Velcro Strap in a Sleeping Bag, Finished and ready!: 5 단계, 이미지 3개 중 1개 How to Repair a Velcro Strap in a Sleeping Bag, Finished and ready!: 5 단계, 이미지 3개 중 2개 How to Repair a Velcro Strap in a Sleeping Bag, Finished and ready!: 5 단계, 이미지 3개 중 3개
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
결론
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
작성자
1다른 기여자 명과 함께
Ben Blischke
회원 가입일: 07/19/23
10,230 평판
안내서 66개를 작성함
INTERSPORT INTERSPORT 회원
Community
25 회원들
안내서 169개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 174
