주요 콘텐츠로 건너뛰기
How to Repair a Warped Cooking Pan
필요한 것
  1. How to Repair a Warped Cooking Pan, How to Repair a Warped Cooking Pan: 1 단계, 이미지 1개 중 1개
    • Locate the hard surface you will use for the repair.
  2. How to Repair a Warped Cooking Pan: 2 단계, 이미지 1개 중 1개
    • Place one of the two towels on top of the hard surface.
  3. How to Repair a Warped Cooking Pan: 3 단계, 이미지 1개 중 1개
    • Turn on the stove to medium heat to warm up the bottom of the cooking pan that is warped.
  4. How to Repair a Warped Cooking Pan: 4 단계, 이미지 1개 중 1개
    • As soon as the pan is warm or hot to the touch, quickly remove it from the stove.
    • Turn off the stove and place the pan, bottom up, on top of the towel that is placed on the hard surface.
  5. How to Repair a Warped Cooking Pan: 5 단계, 이미지 2개 중 1개 How to Repair a Warped Cooking Pan: 5 단계, 이미지 2개 중 2개
    • Place the second towel on top of the bottom of the pan that is facing upward.
  6. How to Repair a Warped Cooking Pan: 6 단계, 이미지 1개 중 1개
    • Place the block of wood on top of the second towel that is placed on the pan.
  7. How to Repair a Warped Cooking Pan: 7 단계, 이미지 2개 중 1개 How to Repair a Warped Cooking Pan: 7 단계, 이미지 2개 중 2개
    • Carefully hammer directly onto the block of wood.
    • Make sure that the block of wood is still firmly on top of the bottom of the pan. This will help ensure that the pan is repaired properly.
  8. How to Repair a Warped Cooking Pan: 8 단계, 이미지 1개 중 1개
    • Your cooking pan should no longer be warped. You are finished!
결승점
작성자
1다른 기여자 명과 함께
angieaguirre
회원 가입일: 02/21/24
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 18
전체 시간: 260
