주요 콘텐츠로 건너뛰기
How to Repair a Warped LP Record
필요한 것
  1. How to Repair a Warped LP Record, How to Repair a Warped LP Record: 1 단계, 이미지 3개 중 1개 How to Repair a Warped LP Record, How to Repair a Warped LP Record: 1 단계, 이미지 3개 중 2개 How to Repair a Warped LP Record, How to Repair a Warped LP Record: 1 단계, 이미지 3개 중 3개
    • Pull your record out of its case, and make sure it is nice and clean.
    • If your record is dirty, you'll want to clean it before starting.
    • Place your clean record in the center of one of the glass panels.
  2. How to Repair a Warped LP Record: 2 단계, 이미지 2개 중 1개 How to Repair a Warped LP Record: 2 단계, 이미지 2개 중 2개
    • Gently set the second glass panel on top of the record.
  3. How to Repair a Warped LP Record: 3 단계, 이미지 3개 중 1개 How to Repair a Warped LP Record: 3 단계, 이미지 3개 중 2개 How to Repair a Warped LP Record: 3 단계, 이미지 3개 중 3개
    • Preheat the oven to warm, or 175 degrees Fahrenheit (or 80 Celsius).
  4. How to Repair a Warped LP Record: 4 단계, 이미지 3개 중 1개 How to Repair a Warped LP Record: 4 단계, 이미지 3개 중 2개 How to Repair a Warped LP Record: 4 단계, 이미지 3개 중 3개
    • Glass can shatter when it experiences temperature shock. Be sure that your glass is room temperature or slightly warm before putting it in the oven, so that it doesn't go from very cold to warm too quickly.
    • Slide your record, sandwiched between the two panels of glass, into the oven.
    • Stay with your record and watch it. If you smell anything funny or hear any strange noises, remove your record from the oven.
    • Warm your record in the oven for 2 or 3 minutes.
    • Leaving your record in the oven for longer may melt your record.
  5. How to Repair a Warped LP Record: 5 단계, 이미지 1개 중 1개
    • Using oven mitts, pull the glass and record assembly out of the oven.
    • Remember that glass can shatter with temperature shock. Do not set your hot glass on a cold granite or tile countertop, or it may shatter!
    • Set the glass on a room temperature table or counter. To protect your surface, place the glass on a potholder or a towel.
  6. How to Repair a Warped LP Record: 6 단계, 이미지 3개 중 1개 How to Repair a Warped LP Record: 6 단계, 이미지 3개 중 2개 How to Repair a Warped LP Record: 6 단계, 이미지 3개 중 3개
    • Weight the glass with heavy books or another flat, heavy object.
    • Leave the record under the weight of the glass and books until it cools completely.
    • When the record is cool, remove it from the glass panels.
결론
Test your vinyl out. If there is still a warp you can repeat the process heating it for just a little longer and weighting it with a heavier object.
다른 44명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brittany McCrigler
회원 가입일: 03/05/12
90,481 평판
안내서 142개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,758개를 작성함
12가이드 댓글
just the same process to fix the graphic card of a macbook pro :-D
(Y) great!
Johan Miller - 답글
Try this: Get two 1/2" x 12" x 12" polished marble floor tiles. Bathe (the tiles) in hot tap water until heated through. Place record in poly sleeve between the two tiles. Place weights on top - the more the better. Wait for tiles to cool. Repeat as necessary.
BooFaar - 답글
BTW - Be sure to dry the tiles after heating.
BooFaar - 답글
When I was a kid, I watched my Mom fix a warped record one time by putting it between the plates of glass and setting it in direct sunlight for about 10 minutes. That worked as well.
OriginalSpins - 답글
Would sheets of stainless steel work? I don't have access to glass sheets.
Carlos Sanchez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 21
지난 7일: 163
지난 30일: 648
전체 시간: 171,390
