주요 콘텐츠로 건너뛰기
How to Repair a Whiteboard Frame
필요한 것
  1. How to Repair a Whiteboard Frame, How to Repair a Whiteboard Frame: 1 단계, 이미지 1개 중 1개
    • Gather all your tools which are listed in the tool area.
  2. How to Repair a Whiteboard Frame: 2 단계, 이미지 2개 중 1개 How to Repair a Whiteboard Frame: 2 단계, 이미지 2개 중 2개
    • Start by applying Goo Gone onto a paper towel to remove any sticky residue from the outside of the whiteboard.
  3. How to Repair a Whiteboard Frame: 3 단계, 이미지 3개 중 1개 How to Repair a Whiteboard Frame: 3 단계, 이미지 3개 중 2개 How to Repair a Whiteboard Frame: 3 단계, 이미지 3개 중 3개
    • Clean the surface using a multipurpose cleaner safe for wood to remove any remaining residue and debris
  4. How to Repair a Whiteboard Frame: 4 단계, 이미지 3개 중 1개 How to Repair a Whiteboard Frame: 4 단계, 이미지 3개 중 2개 How to Repair a Whiteboard Frame: 4 단계, 이미지 3개 중 3개
    • Apply an even amount of glue to each piece, then place them into position and wipe off any excess glue
  5. How to Repair a Whiteboard Frame: 5 단계, 이미지 1개 중 1개
    • Hold all the pieces together for a minute to allow the glue to set firmly.
  6. How to Repair a Whiteboard Frame: 6 단계, 이미지 3개 중 1개 How to Repair a Whiteboard Frame: 6 단계, 이미지 3개 중 2개 How to Repair a Whiteboard Frame: 6 단계, 이미지 3개 중 3개
    • Secure the pieces with clamps at the corners and wait for 24 hours to let the glue dry.
  7. How to Repair a Whiteboard Frame: 7 단계, 이미지 2개 중 1개 How to Repair a Whiteboard Frame: 7 단계, 이미지 2개 중 2개
    • After 24 Hours, remove the clamps carefully.
  8. How to Repair a Whiteboard Frame: 8 단계, 이미지 2개 중 1개 How to Repair a Whiteboard Frame: 8 단계, 이미지 2개 중 2개
    • After 24 hours, remove the clamps and sand down any rough corners if necessary.
  9. How to Repair a Whiteboard Frame: 9 단계, 이미지 2개 중 1개 How to Repair a Whiteboard Frame: 9 단계, 이미지 2개 중 2개
    • Touch up any areas on the whiteboard using black paint where needed.
  10. How to Repair a Whiteboard Frame: 10 단계, 이미지 1개 중 1개
    • Congratulations! Your whiteboard is now fixed and ready to use.
결론
작성자
3다른 기여자 명과 함께
Jelena Drca
회원 가입일: 02/02/24
181 평판
안내서 1개를 작성함
UC Davis, Team 3-9, Andersen Winter 2024 UC Davis, Team 3-9, Andersen Winter 2024 회원
UCD-ANDERSEN-W24S3G9
3 회원들
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 34
전체 시간: 526
