주요 콘텐츠로 건너뛰기
How to Repair an Elastic Loop on a Blouse
필요한 것
  1. How to Repair an Elastic Loop on a Blouse, How to Repair an Elastic Loop on a Blouse: 1 단계, 이미지 1개 중 1개
    • Place the broken elastic loop back in its original position on the blouse.
  2. How to Repair an Elastic Loop on a Blouse: 2 단계, 이미지 1개 중 1개
    • Double thread the needle.
    • Pass the needle through the base of the elastic loop.
  3. How to Repair an Elastic Loop on a Blouse: 3 단계, 이미지 2개 중 1개 How to Repair an Elastic Loop on a Blouse: 3 단계, 이미지 2개 중 2개
    • Pass the needle through the stitch line where the elastic loop was originally secured, then back through the base of the elastic loop, at least 6-7 times.
    • Don't pull the thread tight; leave a loop to tie off the thread.
    • Insert your needle through the loops, then pull the thread tight.
  4. How to Repair an Elastic Loop on a Blouse: 4 단계, 이미지 1개 중 1개
    • Simply cut the thread connected to the needle, and then any dangling threads.
결론
Enjoy your revitalized garment!
작성자
1다른 기여자 명과 함께
IAHN C ROSADO-LAUSELL
회원 가입일: 03/18/22
109 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 72
전체 시간: 5,317
