주요 콘텐츠로 건너뛰기
How to Repair an Unhooked Zipper
필요한 것
  1. How to Repair an Unhooked Zipper, How to Repair an Unhooked Zipper: 1 단계, 이미지 2개 중 1개 How to Repair an Unhooked Zipper, How to Repair an Unhooked Zipper: 1 단계, 이미지 2개 중 2개
    • Check the opening of the slider to see if it is too wide.
    • When it is too wide, it does not latch on to the chains properly.
    • Use the pliers to lightly tighten the slider on each side.
  2. How to Repair an Unhooked Zipper: 2 단계, 이미지 2개 중 1개 How to Repair an Unhooked Zipper: 2 단계, 이미지 2개 중 2개
    • Place the scissors horizontally at the bottom of the chain that is not connected to the slider.
    • Make a small cut of about 3 millimetres.
  3. How to Repair an Unhooked Zipper: 3 단계, 이미지 2개 중 1개 How to Repair an Unhooked Zipper: 3 단계, 이미지 2개 중 2개
    • Pull the slider up gently through the opening to see if the zipper is now working.
  4. How to Repair an Unhooked Zipper: 4 단계, 이미지 3개 중 1개 How to Repair an Unhooked Zipper: 4 단계, 이미지 3개 중 2개 How to Repair an Unhooked Zipper: 4 단계, 이미지 3개 중 3개
    • In order to set up the needle and thread, you will need to take about 70 centimetres of thread and pull it halfway through the hole at the bottom of the needle. Make sure both sides of the thread are equal lengths and bring them together.
    • Tie the loose end of the thread into an overhand knot. This is where you make a loop and pull the thread through it.
    • Make sure to do this at least 2-3 times so it does not come undone during the sewing process.
    • For the purpose of this guide, I used a colour that is easy to see on the fabric. However, try to use thread that matches your zipper.
  5. How to Repair an Unhooked Zipper: 5 단계, 이미지 3개 중 1개 How to Repair an Unhooked Zipper: 5 단계, 이미지 3개 중 2개 How to Repair an Unhooked Zipper: 5 단계, 이미지 3개 중 3개
    • Starting at the opposite side of the cut, weave the thread under and over the zipper.
    • While staying in one spot, weave and tug at the thread to close the hole.
    • Closing this hole will ensure that over time the zipper does not wear out the part of the chain that was cut.
  6. How to Repair an Unhooked Zipper: 6 단계, 이미지 3개 중 1개 How to Repair an Unhooked Zipper: 6 단계, 이미지 3개 중 2개 How to Repair an Unhooked Zipper: 6 단계, 이미지 3개 중 3개
    • When the hole looks covered completely, loop the thread and sew the needle through it to finish sewing.
    • Cut off excess thread and check if the zipper is working.
    • Always do the loop and sew through it at least three times to make sure it is secure.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Jannatul Khorshid
회원 가입일: 09/16/20
187 평판
안내서 1개를 작성함
York University, Team S2-G31, Melo-Thaiss Fall 2020 York University, Team S2-G31, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G31
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 67
지난 30일: 321
전체 시간: 7,415
