주요 콘텐츠로 건너뛰기
How to Repair the Base of a Dresser
필요한 것
  1. How to Repair the Base of a Dresser, How to Repair the Base of a Dresser: 1 단계, 이미지 1개 중 1개
    • Remove all drawers from the dresser.
  2. How to Repair the Base of a Dresser: 2 단계, 이미지 1개 중 1개
    • Turn the dresser upside so that the bottom is facing up.
    • You may need to turn the dresser on its side for easier access to the damaged portion of the base.
  3. How to Repair the Base of a Dresser: 3 단계, 이미지 1개 중 1개
    • Using a pair of pliers, remove the existing staples from the bottom of the dresser.
  4. How to Repair the Base of a Dresser: 4 단계, 이미지 1개 중 1개
    • Remove the piece of hardboard and realign it so that it is in the position you desire.
  5. How to Repair the Base of a Dresser: 5 단계, 이미지 1개 중 1개
    • Use the staple gun to staple the hardboard back to the frame of the dresser.
    • Never have staples in the staple gun until you are ready to use it and keep all hands at a safe distance from the staple gun while in use to minimize the risk of an injury.
  6. How to Repair the Base of a Dresser: 6 단계, 이미지 1개 중 1개
    • Using the tape measure, measure the distance between the two sides of the dresser frame and then cut a beam of wood to fit these specifications.
    • Be sure to measure the beam of wood as close as possible to ensure that the beam is not visible while viewing the dresser and it will not impede the drawers in any way.
  7. How to Repair the Base of a Dresser: 7 단계, 이미지 1개 중 1개
    • Using the drill, screw the beam of wood into place.
    • It is not necessary to drill guide holes into the beam of wood before screwing the beam into place.
결론
To reassemble your dresser, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Caitlin Serafine
회원 가입일: 07/12/17
131 평판
안내서 1개를 작성함
Texas Tech, Team S1-G3, Rauch Summer 2017 Texas Tech, Team S1-G3, Rauch Summer 2017 회원
TTU-RAUCH-SU17S1G3
3 회원들
안내서 1개 작성
1가이드 댓글
Hmm not sure how do refix the dressers
Megan Gellert - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 25
전체 시간: 5,136
