주요 콘텐츠로 건너뛰기
How to Repair the Buttons on a Logitech Pebble Mouse
필요한 것
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 1/3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 2/3 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 3/3
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 1/3 How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 2/3 How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 3/3
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: 3 단계, 이미지 1/2 How to Repair the Buttons on a Logitech Pebble Mouse: 3 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 1/3 How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 2/3 How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 3/3
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: 5 단계, 이미지 1/1
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 1/3 How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 2/3 How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 3/3
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emma Whitmer
회원 가입일: 04/19/23
151 평판
안내서 1개 작성함
UC Davis, Team 2-6, Morris Spring 2023 UC Davis, Team 2-6, Morris Spring 2023 회원
UCD-MORRIS-S23S2G6
3 회원들
안내서 1개 작성하였습니다
댓글 2개
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - 답글
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 36
30일 전: 147
전체 시간: 1,903
