주요 콘텐츠로 건너뛰기
How to Repair the Buttons on a Logitech Pebble Mouse
필요한 것
  1. How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 3개 중 1개 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 3개 중 2개 How to Repair the Buttons on a Logitech Pebble Mouse, How to Repair the Buttons on a Logitech Pebble Mouse: 1 단계, 이미지 3개 중 3개
    • Use your hands to remove the magnetic top panel of the mouse.
  2. How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 3개 중 1개 How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 3개 중 2개 How to Repair the Buttons on a Logitech Pebble Mouse: 2 단계, 이미지 3개 중 3개
    • Remove the USB adaptor in the small rectangular hole on the lower right corner.
    • Remove the battery.
  3. How to Repair the Buttons on a Logitech Pebble Mouse: 3 단계, 이미지 2개 중 1개 How to Repair the Buttons on a Logitech Pebble Mouse: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove one screw holding the inner panel in place.
  4. How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 3개 중 1개 How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 3개 중 2개 How to Repair the Buttons on a Logitech Pebble Mouse: 4 단계, 이미지 3개 중 3개
    • Remove the the inner panel.
    • This may take a little bit of effort but it should come off fairly easily.
    • You can use the battery socket as leverage to remove the panel. To avoid breaking the panel, be gentle but firm.
  5. How to Repair the Buttons on a Logitech Pebble Mouse: 5 단계, 이미지 1개 중 1개
    • Use a fine-tipped object or a Q-tip and dip it in a small amount of oil.
  6. How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 3개 중 1개 How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 3개 중 2개 How to Repair the Buttons on a Logitech Pebble Mouse: 6 단계, 이미지 3개 중 3개
    • Gently wipe the metal axle where the scroll wheel is mounted with a small amount of 3-in-1 oil.
    • Repeat for the left and right click buttons.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Emma Whitmer
회원 가입일: 04/19/23
205 평판
안내서 1개를 작성함
UC Davis, Team 2-6, Morris Spring 2023 UC Davis, Team 2-6, Morris Spring 2023 회원
UCD-MORRIS-S23S2G6
3 회원들
안내서 1개 작성
5가이드 댓글
At first i'm laugh about fixing button with oil, but then i tried it... and it worked like a charm!
Marat - 답글
I didn't even disassemble (unscrew) my pebble. Just applied a drop of mineral oil to the button and it did help a lot! Thanks!
Tomek Luzak - 답글
Hi Emma, Is it fine to use the spray version of wd40 if not what is the difference?
Best
Hakan
Hakan Toptas - 답글
I'm finding the issue with my new Pebble isn't so much that the buttons don't work. It's that they are unreliable because if you don't press near dead center on the button, it doesn't actuate enough to press the microswitch. I feel like this is a design flaw, but maybe this guide will help. On the plus side, at least they built it where it's easy to take apart.
Stephen Speck - 답글
Wow, it worked really well! Although on the first day, there were still some clicking issues. But by the second day, everything seemed fine
Yuriy Z - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 34
지난 30일: 172
전체 시간: 4,880
